Old 11-18-2014, 06:19 PM   #1
2013 28' International
Bozeman , Montana
Adding humidity while in storage
We are going to store our Airstream in the Phoenix area this winter for the first time. In the past we have always stored it and boats in Michigan and the concern is dealing with any humidity.
When I was at a local dealer this week they recommended that we leave a bucket of water in the shower so they trailer is not so dry (wood drying out and cracking).
I'm wondering if anyone else does this or has heard of it? By the ways, we are in our own full enclosed but not heated/cooled storage unit.
We will probably be back down in 6-8 weeks to use it again so not a super long time.
Thanks!
HeadWest is offline   Reply With Quote
Old 11-18-2014, 06:27 PM   #2
terryV's Avatar
2002 31' Classic
Monroe , Iowa
I'm certainly no expert, but, if you're going to use it every month or two, do you really need to worry about it drying out?
terryV is offline   Reply With Quote
Old 11-18-2014, 07:10 PM   #3
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
I'd think the pail of water would add humidity in the short term, but would likely evaporate within a few weeks. I wouldn't worry about it very much, especially since you're keeping the sun off her. They park all those airplanes out in the dry desert for years, they preserve there quite well because the humidity is low. Dry is good, except maybe for guitars and cigars.
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 11-19-2014, 01:50 AM   #4
2005 19' Safari
GLENDALE , AZ
Our 2005 19' Bambi has been parked next to our house in Phoenix, since it was purchased new. Absolutely no problems with low humidity, even in 118 degree heat. I suspect Airstreams in northern states have more problems with freezing and water leaks, which are not a problem in central Arizona, than we do with low humidity and summer heat.
Old 11-19-2014, 05:39 AM   #5
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Humidity is your enemy. I live in a naturally humid climate, where 75% relative humidity is considered "dry"! It's a constant battle against mold and mildew.
If you're worried about your wood, use a good furniture wax to seal the pores in the wood, especially on end grains, and call it good enough.
As for a pan of water in your shower, that's silly. If you want water, fill your toilet bowl almost to the rim. Not only will it provide some humidity to the air (not a lot, but some), it will keep your toilet seal moist longer, too. Which is also a good thing. And if the water in the toilet bowl gets stagnant before you return, dumping it is easy; just flush!
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 11-19-2014, 11:26 AM   #6
B00merang's Avatar
2010 20' Flying Cloud
Hailey , Idaho
HeadWest
I have stored/used my 20ft FC here in Idaho for the past 4 years. Its high desert... dry as can be...and have seen no damage to any of the woodwork or rest of the interior. I'd advise to add wheel covers, but you're storing her inside, so she'll be fine. Jon
B00merang is offline   Reply With Quote
Old 11-19-2014, 11:40 AM   #7
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
The amount of water evaporating out of three 5 gallon buckets we have in our 2014 Classic stored in the shade but outside in the heat at the east edge of Phoenix is pretty amazing. Since we have solid Hickory wood cabinets, we are interested in the humidity staying relatively constant to prevent cracking.
We have a veneer curling issue on the bottom of the large overhead cabinet in the living room area. That will be a future repair made by replacing the bottom with solid Hickory wood rather than the factory laminated plywood.
Old 11-19-2014, 11:52 AM   #8
BeachHouse's Avatar
2005 25' International CCD
Lilburn , Georgia
And, since you have an International, I doubt if you have any wood. It is all plywood with laminate.
BeachHouse is offline   Reply With Quote
Old 11-19-2014, 05:30 PM   #9
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Put a 5 gallon bucket three quarters full of water in it, it don't cost any thing, and it can't hurt anything...
Old 11-20-2014, 07:04 AM   #10
2011 23' Flying Cloud
Durango , Colorado
There is no hardwood in our Airstream that would crack due to low humidity, unlike our skin and Indonesian Teak furniture that relocated with us to Durango, CO. Low humidity is great for storage.
Cheers,
JamuJoe
Safe Travels,
Joe & Joan Donnaway
Durango, CO
JamuJoe is offline   Reply With Quote
Old 11-20-2014, 07:24 AM   #11
Bozeman , Montana
Thanks for the suggestions. I did decide to skip the bucket of water since it will not be in storage that long and it is not being stored in the heat of the summer. We are pretty happy with the storage facility we found in Phoenix but it is pricey, about $350 per month for a 35' individual unit.
Back to the cold.
Old 11-20-2014, 07:32 AM   #12
Actually not that pricey. That works out to about $1 per square foot per month. Less than you'd pay in many other parts of the country. I've seen quotes on self-storage in New York for $2.75 per square foot per month!
WBCCI #1105
TAC LA-4
Humidity while storing SeymourAC 2009-2015 Flying Cloud 5 03-14-2012 06:47 AM
Controlling humidity Catman6 Full-Timing 23 03-31-2010 02:55 PM
Florida Storage & Humidity monkeypants Our Community 10 09-17-2009 07:29 AM
Humidity JLD Dehumidifiers & Ozone Generators 6 01-28-2008 06:08 PM
Controlling Humidity chaimemet Dehumidifiers & Ozone Generators 2 06-17-2007 06:07 AM
