Originally Posted by GMFL
Under the street side closet there is a door with a furnace vent in it. That door will open towards the front of the trailer. The water pump is behind it. You should be able to slip you fingers into the seem between the door and the frame at the bottom of the door.
Brilliant! Thank you so much!
I had already discovered that before seeing your post. FYI - The input line to the pump is on the side closest to the door.
I used a 90 degree PEX connector with a hose clamp to connect 5' of clear 1/2" clear vinyl tubing that I bought at Ace hardware. Worked great and had no problems with the fit. No leaks. Sucked in a gallon of antifreeze fluid in about 20 seconds!
