Old 11-19-2013, 01:12 PM   #1
1990 29' Excella
Long Island , New York
'90 Excella Fresh Water Tank Drain?
Ok, so Im trying to winterize this thing, I found the 2 low point drains under the pantry, how do I drain the fresh water tank? I don't see any external valve underneath, I guess I'll just let the water pump handle it?
Idk. Any ideas?
Jeepjunk4 is offline   Reply With Quote
Old 11-19-2013, 01:21 PM   #2
Rivet Idiot
AirHeadsRus's Avatar
1999 34' Excella
On The Lake , Georgia
My drain is on the street side between the tires. Look for a white colored petcock valve.
AirHeadsRus is offline   Reply With Quote
Old 11-19-2013, 01:41 PM   #3
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
Does anyone know if the '90 25' Excella is the same as the 29'? I've winterized my trailer but I'm a little concerned. This was my first time winterizing it and I used compressed air since I don't think it has a hot water heater bypass. It's going down to 10 degrees here tomorrow night. The trailer is in a non-heated enclosed barn several miles away and I'm thinking of driving over to double check it. I don't recall seeing any low point valves.
I'd really appreciate your input.
Poppy
John & Vicki
WBCCI #4291
Grown men don't need leaders. ~ Edward Abbey
John&Vicki is offline   Reply With Quote
Old 11-19-2013, 02:16 PM   #4
1990 29' Excella
Bird u need to look on the backside of the water heater. Mine is on the curbside under the bathroom vanity, if you see any kind of handle back there thets ur bypass, if not as long as u drained ur water heater, u should be ok.
If I look between the tires on the curbside, there is a white disk attaced to the side of the pan. I've wondered what that was. It looks like the handle is gone and a black plastic vacuum cap is placed over the stem where the missing handle should be! At least I know what supposed to be there now. lol
Old 11-19-2013, 02:30 PM   #5
1990 29' Excella
The low points on ur model are under yhe pantry and stove area. If I didn't no where mine were I would never have found them. Theyre small grey t valves. pull up and turn counterclockwise about 5 turns, when u close em they don't stop, kinda odd I thought. Bring a flashlight, mine were buried under the heating ducting!!!
Old 11-19-2013, 02:52 PM   #6
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , WNY
Thumbs up
Poppy,
Did you drain the HWT?
PFC
but I’m the Husband, so we went to Cleveland.
RLC
Step aside Starbucks, this is a job for alcohol.
Old 11-19-2013, 04:00 PM   #7
1986 25' Sovereign
Allegan , Michigan
My unit had the white plastic petcock fresh water tank drain with access between the tires curbside. I say "had " because it broke this spring and I had to make an emergency repair. I think that it will unthread if you find that you can't make it drain - but can't really remember. (The repair was a male garden hose thread with a cap for the valve - works so far.)
Other advice is to use as little pink antifreeze in the fresh water supply as possible - none is best - compressed air works for my unit. Only used pink once, next spring the water had a tint even after a great deal of flushing. Our dog would not drink it - had to haul water for her. Sort of surprising based on what she used to find in the woods and then eat!
Not sure what my unit should be described as; 25 foot center bath with "Sovereign" on the side and "Excella" on the can that hides the propane tanks.
Good luck,
Whit Nash
rwnash is offline   Reply With Quote
Old 11-19-2013, 06:00 PM   #8
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
Thanks for the input everyone. I just got back from the Sheep Barn at the county fairgrounds where Nellie is biding her time until we pull out of here in November. Went through everything and I feel comfortable now.
Poppy
John & Vicki
WBCCI #4291
Old 11-19-2013, 07:11 PM   #9
Olie's Avatar
2004 30' Classic
Beaumont , Texas
Idk. Any ideas?
In my 04 Classic it's a white petcock behind the front street side tire. You have to crawl under the RV to reach it unless you have 4' long arms.
Mine is very hard to turn. I'm afraid the handle is going to brake, it takes that much pressure to turn it. How do you lubricate the thing, doesn't look like it can taken apart? I've used WD40 which helps but still tight.
Olie is offline   Reply With Quote
Fresh Water Tank Location & Size VeggieBullet Plumbing - Systems & Fixtures 9 10-20-2011 06:23 PM
Fresh Water Tank and City Water ??? tr0y Fresh Water Systems 3 08-29-2011 05:49 AM
Fresh Water tank '68 safari series2a Fresh Water Systems 1 07-05-2011 04:24 PM
Fresh Water Tank Size and Gauges ednspace Fresh Water Systems 4 05-23-2011 09:19 PM
Grey Water Tank Flushes Toilet (to conserve fresh water) LittleRadio Sinks, Showers & Toilets 8 03-28-2011 11:10 AM
