Old 11-20-2013, 08:23 AM   #1
1990 29' Excella
Long Island , New York
'90 Excella drain????
Ok so just when ya think u have it all figured out...
Looking between the tires on the street side this is what I see. I thought the handle had snapped off the tank drain, but I was able to unscrew it and it appears to be a brass nipple with a vacuum cap over it?????
Somebody learn me here!!!!!
ID:	200360   Click image for larger version
Jeepjunk4 is offline   Reply With Quote
Old 11-20-2013, 08:30 AM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
That is a lousy patch job from a broken valve.
There are brass ones. However the plastic breaking is better than damaging the tank cover it is screwed to.
So near tires, it is better, I think, to let the soft plastic break than damage stuff thrown up by tires.
Bottom line, buy a new valve. Unscrew the old one by removing the two screws and pull out. There wil e a clear hose, clamped to the broken valve. Swap them out and reinstall.
Peace and Blessings..
Channing
WBCCI# 30676
Old 11-20-2013, 09:13 AM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Look up "out of doors mart"
Channing
WBCCI# 30676
Old 11-20-2013, 11:40 AM   #4
1990 29' Excella
Thanks Channing. So I was on the right track, it was the original tank drain with a bad repair job. I will repair it right. Thanks for your help.
Is there a drain for the AC? perryg114 Furnaces, Heaters, Fireplaces & Air Conditioning 14 11-13-2011 06:06 PM
How to drain? sarasafari Waste Systems, Tanks & Totes 1 09-17-2011 01:02 PM
1988 Excella AC Drain Problem 68Glbtrotter Furnaces, Heaters, Fireplaces & Air Conditioning 4 06-04-2011 06:01 PM
Excella Info? M Williams 1981 - 1983 Excella 4 01-26-2011 07:13 PM
