Old 05-06-2007, 09:44 AM   #1
1977 24' Argosy 24
Mountlake Terrace , Washington
Yet another jacking question
First I read all the threads and then looked at my 77 argosy 24t. My axle mount plates are just vertical plates and I see now C channel for the frame. The shock mounts are also bolted to this vertical plate. Can I jack at the shock mount between the tires?
Sorry for the question but I want to be clear on this before I jack up the trailer to ck the brakes. Hoping for help.
Brian
w/oapaddle is offline   Reply With Quote
Old 05-06-2007, 12:00 PM   #2
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
I usually jack on that vertical mounting plate, myself. Many posts will tell you to never jack on the axle. The location of the "jack here" stickers on my Caravel were just aft of the mounting plate, directly under the frame.
Some folks think you will bend the frame, others are concerned that the thin edge of the mounting plate makes it more likely to somehow scoot off the jack. I think either the frame right aft of the mounting plate or the moutning plate itself are fine, just watch out for interference of tire/wheel as you jack.
Stay off the axle.
Zep
Old 05-06-2007, 01:48 PM   #3
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
After dropping belly panels I will never jack anywhere but on verticle axle bracket. The indicated spots are merely for stabilizer locations - lifting trailer from these points damages frame and chances collapse from betting the jack is at correct point; attempting to lift from axle is final doom to the axle...
Old 05-06-2007, 05:55 PM   #4
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
If you jack on the axle mounting plate you can easily bend it or slip off it. It is particularly dangerous if your jack is on a soft surface like grass or uneven such as gravel. If you are on asphalt you might get away with it. I always go the safe route and jack on the frame just ahead of or behind the wheels. If the decal is missing, you can judge by the location of the rivets. Remember to always have the unit still attached to the TV or blocked front and back on the other side to prevent movement. The tonque jack stand is not enough to guarentee things will stay stationary.
Old 05-06-2007, 05:59 PM   #5
1977 24' Argosy 24
I've jacked hundereds of vehicles from the shock point as it is a stressed member and supports the frame/body. So am I safe in assuming that it is safe to jack from this point Between the wheels>
Brian
Old 05-07-2007, 11:08 AM   #6
Brian
Jacking the trailer from a shock stud, should never be done.
That stud will bend causing another problem.
Jacking from the axle mounting plate is the only, "safe", option.
Old 05-10-2007, 06:17 AM   #7
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Brian
Shocks never support frame/body members on any vehicle. That is the job of a spring. The function of a shock is to dampen movement only. If the shock mounting point is attached to an axle you may get away with the above lifting proceedure. (Key word is may) Lifting a vehicle from a shock mounting point was not in the design on that part for almost any vehicle.
>>>>>>>>>>>>>>>>>Action
Skylight part question ColtSAA45 Roof Vents, Skylights & Fans 3 04-22-2004 08:05 PM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Tire sizing question casarodante Tires 5 07-02-2002 10:19 PM
Hello from new Forumee - and a question about front shocks on my 1989 345LE williamhenshall Mechanics Corner - Engines, Transmission & More... 12 04-14-2002 10:13 AM
