Originally Posted by Steamy1
I also use the Fastway.
When I need to level one side, I use these heavy duty pads to create a platform under and between the tires. The Fastway rests on the pads between the tires. Very stable and secure.
?? How do you position the leveling pads? The bottom pads need to be facing same direction, right? So that means the Fastaway chocks can not get a grip on the front tire, from my observance, which is why we use the X-chocks. Do you have a picture of your Fastaway set up on the levelers? you can share?
As I mentioned, the X-chocks are an issue when the tire is
wet and your on an angle. Once your set up level, they work fine; just make sure to tighten to avoid any movement when level
2017 28' Twin Flying Cloud
