Old 03-21-2019, 04:26 PM   #41
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
I also use the Fastway.
When I need to level one side, I use these heavy duty pads to create a platform under and between the tires. The Fastway rests on the pads between the tires. Very stable and secure.
Name:	Utility Block.jpg
ID:	336250   Click image for larger version
Name:	Utility Block2_.jpg
Steamy1 is offline   Reply With Quote
Old 03-21-2019, 04:57 PM   #42
2018 25' International
Tempe , Arizona
Originally Posted by gypsydad View Post
They look pretty nice on flat ground, but how do you use them when wheel's need to be on lego-blocks for leveling?? Seems you still would need the X-chocks?
We use the Anderson leveler on one side, and the Fastway on the other.
january2022 is offline   Reply With Quote
Old 03-22-2019, 09:55 AM   #43
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
?? How do you position the leveling pads? The bottom pads need to be facing same direction, right? So that means the Fastaway chocks can not get a grip on the front tire, from my observance, which is why we use the X-chocks. Do you have a picture of your Fastaway set up on the levelers? you can share?
As I mentioned, the X-chocks are an issue when the tire is wet and your on an angle. Once your set up level, they work fine; just make sure to tighten to avoid any movement when level.
2017 28' Twin Flying Cloud
2017 F250 King Ranch, 4X4, Blue-Ox WDH
Summer in Lincoln, MT- Winter in Austin, TX
Old 03-22-2019, 11:05 AM   #44
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
My gizmo for soft ground,(all ground really), 3/4 marine ply with stops to keep the lego's from moving as you back on.
Like me all my stuff is old, it just works better. 😂
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 04-09-2019, 07:22 PM   #45
2016 26' Flying Cloud
Spooner , Wisconsin
My experience is like Bgibbs. I wrenched them on as tightly as I could with my own 17mm ratchet (the wrench that came with it was junk.) I parked it on my wild 40 and was installing a little security. I went back some weeks later and forgot to remove them. I found them about two feet from where they were installed. Maybe they keep the AS from rolling, but they certainly don't stop it from being stolen.
WherryWillie is offline   Reply With Quote
Andersen Camper Wheel Leveler and Chock + X-Chock? Airhills On The Road... 13 07-06-2017 10:35 AM
WTB Level-It Aluminum Wheel Chock thinairflyer Airstream Classifieds 3 01-18-2016 09:12 PM
Wheel chock locks and wheel covers MaineStreamer On The Road... 30 01-04-2015 11:52 PM
X-Chock Wheel Chock's kscherzi Wheels, Hubs & Bearings 10 03-13-2013 10:08 AM
BAL Tire Locking Chock nazz300 Tires 5 04-18-2006 01:07 PM
