Old 11-21-2010, 04:13 PM   #1
A.K.A "THE STREAM"
THEPILL's Avatar
2010 25' FB International
Arlington , Texas
Wow I can't believe I'm asking this 9 months...
,,,after ownership, but here goes.
Levelingjacks.
How much do you crank on them? It hasn't been a issue because all of the sites I've been to have had concrete pads which are pretty much level. But are you suppose to crank on them until the Airstream is level, or are they mainly just to support the frame for long periods of storage. Can you over crank them?
Thanks.
Shane
http://i52.photobucket.com/albums/g2...h_postcard.jpg
"Stay Thirsty My Friends"
Tow Vehicle" 2011 Superduty Diesel!!"
TAC ID TX-1432
THEPILL is offline   Reply With Quote
Old 11-21-2010, 04:18 PM   #2
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Levelingjacks.
Thanks.
Shane
Shane,
Those aren't leveling jacks on your trailer. They are stabilizing jacks meant to take the rock and roll out of the trailer. You level the trailer from side to side with something under the tires. The front to back level is done with the hitch jack. Once level you drop the stabilizing jacks down to make the trailer secure from motion.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 11-21-2010, 04:20 PM   #3
A.K.A "THE STREAM"
THEPILL's Avatar
Arlington , Texas
Originally Posted by jcanavera View Post
Shane,
Jack
Thanks, thats the way I was treating it.
Figured that. didn't look sturdy.
Shane
TAC ID TX-1432
Old 11-21-2010, 04:20 PM   #4
blmitch5's Avatar
2006 19' International CCD
Olathe , Kansas
You just use them to stabilize the trailer not to level it. You need to use leveling blocks to level it (look like legos). Sometime you need to use alot, we have two sets. Don't try to level your trailer with the stabilizers.
blmitch5 is offline   Reply With Quote
Old 11-21-2010, 04:21 PM   #5
dznf0g's Avatar
Oswego , Illinois
Support only. Just enough to stop unwanted motion, or rocking. I turn approx. 1/2 turn after contact with the ground. AND EQUALLY. It's really easy to put enough twist to have your door(depending upon location) not latch easily. If your on soft ground or even gravel, it may be necessary to re-tighten after several hours, or more, to maintain "good footing. They are not for leveling.
Old 11-21-2010, 04:24 PM   #6
blmitch5's Avatar
Olathe , Kansas
Heres a pic. We got ours at Walmart.
Tri Lynx 00015 (10) Lynx Leveler:Amazon:Automotive
Old 11-21-2010, 04:37 PM   #7
A.K.A "THE STREAM"
THEPILL's Avatar
Arlington , Texas
Thanks all.
Shane
TAC ID TX-1432
Old 11-21-2010, 06:18 PM   #8
JimW's Avatar
1997 30' Limited
Omaha , Nebraska
Hey Shane,
Our present AS has electric powered stabilizers, but our previous SOB's did not. I always carried an 18v screw driver with a 1/2 inch socket driver and the 3/4" socket to lower and raise the stabilizers. It made the whole process quick and easy. And to be honest, I think the system worked easier and faster than the system that I have now. I still carry the 18v drill as I find it handy for numerous applications while on the road.
Black Friday is coming up and the 18v drill may be a bargain at Ace hardware, Home Depot, etc.
JIM
Rig: '97 30' Limited
Towed by: '13 Silverado 2500 Duramax
WBCCI #22116
JimW is offline   Reply With Quote
Old 11-21-2010, 06:21 PM   #9
A.K.A "THE STREAM"
THEPILL's Avatar
Arlington , Texas
Originally Posted by JimW View Post
Hey Shane,
JIM
Thanks, Jim but I like the exercise of cranking the stabilizer jacks.
After they are down, well then I kn ow my job is done and time for a beer.
Shane
TAC ID TX-1432
Old 11-21-2010, 06:26 PM   #10
JimW's Avatar
1997 30' Limited
Omaha , Nebraska
Shane
OK Shane,
Now we're talkin'. Exercise ... then a beer. It just can't get any better than that. I hope we can enjoy a brew together sometime.
JimW
Name:	Pt Townsend Brew.jpg
WBCCI #22116
Old 11-21-2010, 07:56 PM   #11
SRW
TEXAS66
SRW's Avatar
Georgetown , Texas
Cool When to Lower the Stabilizers
Do not lower the stabilizers until after the Airstream has been leveled.
If you forget and the front of the Airstream required raising to level the Airstream, after the rear stabilizers are lowered, they could be over stressed and will be difficult (if not impossible) to raise.
Not so surprisingly, the same situation will occur with the front stabilizers if the Airstream is lowered at the front with the front stabilizers already in the down position.
Do not forget to raise all stabilizers before moving the Airstream.
Newbie mistakes - not necessarily.
TEXAS66
SRW is offline   Reply With Quote
Old 11-27-2010, 01:39 PM   #12
Capt W
2013 31' Classic
Jefferson , Massachusetts
Glad I found this thread
I am a newbie AS owner. Haven't even picked it up yet. But, I've spent hours here in the forums.
I've learned a lot, and the information about the stabilizers was very good to find. I thought they were leveling jacks.
One thing I'd like to know, what's up with the 1 Rivet, 2 Rivet etc?
W
wrochdvm is offline   Reply With Quote
Old 11-27-2010, 02:23 PM   #13
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
The more posts, the more rivets. If you have 5 rivets (500 posts), you need to think about getting a life.
Gene
Old 11-27-2010, 02:25 PM   #14
1973 31' Excella 500
Spring Green , Wisconsin
W
Rivet accumulation is covered in post #17 here:
http://www.airforums.com/forums/f138...tml#post613497
Yes, the forums are a great resource for those of us who have so much to learn...
Lew TAC #WI-6
Nobody can help everybody, but everybody can help somebody.
driftless is offline   Reply With Quote
10 Months Later - Still No Airstream GACStreamer Member Introductions 9 06-26-2011 04:03 PM
My last 24 months... PaulO Full-Timing 9 11-24-2008 12:10 PM
If you had two months in the west..... Boondocker On The Road... 83 04-23-2007 07:51 AM
Been Lurking for Months, Thanks! Keenan Member Introductions 5 09-11-2006 01:43 PM
Six whole months Pahaska Our Community 3 12-02-2002 08:44 AM
