Old 06-25-2011, 06:34 PM   #29
Cracker's Avatar
Pittsfield , Maine
Originally Posted by captmatt View Post
Great info everyone, Thanks from all us newbies! 'Cracker', your idea of the 2 x 8 stacking pyramid sound perfect, inexpensive, multifunctional and best of all I can make it myself. How high do you need to say, check the bearings? Is 3 levels of 2x8's enough? I assume the base or bottom boards should be just long enough to fit between the tires.
No - with respect to board length --- the stack I use starts with a 4'-6" long board, with each succeeding board shortened by 4" overall, and centered on the board below (---creating a ramp on either end of the stack) until the top board remains long enough to fully support both axles when the trailer is centered on the stack. Again, I use four boards and - when on a hard surface - three boards will generally raise the suspended axle enough to clear the ground. I also beveled the top ends of the boards about 1" on a 45% slope to ease the ramp slightly. The trailer easily climbs the ramp and, if it were much shallower, it would be difficult to "suspend" one axle for service (---lack of clearance!) I carry the stack "made up" across the rearmost end of my pickup bed, strapped in place using nylon cargo straps - but your transport configuration will probably vary. The remaining detail I used for the "pegs" consists of 1/4" diameter x 1 1/2" long galvanized lag bolts screwed into the bottom of each upper board, with a stack of washers fitted on each bolt to produce a peg about 3/4" long. I used 4 pegs per board with the matching female holes drilled in the top of the lower board. That way there's nothing sticking up when you use only two or three boards. The bottom board doesn't have pegs and the top board doesn't have holes. A coat of paint keeps the boards in good shape when they have to stay out in the rain and mud! The long length of the stack actually makes getting the trailer up on the boards fairly easy since lining the boards up parallel to the side of the trailer with the stack positioned on the tire is a piece of cake. The only tricky part is placing the stack where you want the trailer to stop - either by backing it on or pulling it ahead.
Cracker
Cracker is offline   Reply With Quote
Old 06-26-2011, 04:12 PM   #30
captmatt's Avatar
1986 31' Sovereign
Naples , Florida
Thanks Cracker, I had two stacks in mind but the use of one for both axles (just one axle for service needs) makes it that much easier! I'll be sure to keep room in the truck bed for my new leveling planks! I appreciate the details!
Matt
captmatt is offline   Reply With Quote
10 Months Later - Still No Airstream GACStreamer Member Introductions 9 06-26-2011 04:03 PM
My last 24 months... PaulO Full-Timing 9 11-24-2008 12:10 PM
If you had two months in the west..... Boondocker On The Road... 83 04-23-2007 07:51 AM
Been Lurking for Months, Thanks! Keenan Member Introductions 5 09-11-2006 01:43 PM
Six whole months Pahaska Our Community 3 12-02-2002 08:44 AM
