Old 11-18-2005, 04:59 AM   #1
Wiring question about ol' Jack
Last year my univolt died so I replaced it. In the process I also replaced the old glass fuse panel with a bladed one. I didn't connect the car battery charge line (blue line) because I never have my truck connected to my trailer when hooked up to shore power. Now all 12 volt circuits work except my electric tongue jack. Could this be the result of not connecting the blue line?
Or, could it be because I seem to have found an extra wire coming out of what looks to be a solenoid directly under my jack motor. I don't remember this wire not being connected last year, when my jack worked fine. I have one wire coming from my switch and connecting to a wire from my trailer tongue. Two wires coming from the solenoid? one being connected to another wire coming from the trailer tongue and the other just swinging loose. I was wondering if this wire should be grounded to the trailer? The jack is an old one ('71 Excella). Any help will be greatly appreciated!!! And fast please as I would like to hit the road this afternoon.
JoBuckaroo is offline   Reply With Quote
Old 11-18-2005, 05:06 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Welcome to the forums!
A tongue jack is like any other piece of electrical equipment, it will need power and ground in order to work. It sounds like your ground wire came loose, try touching the end of this wire (with some wire exposed) to the jack itself, or something else metal that is connected to the trailer, anbd try to operate the jack. If it works, you have your answer. If nothing happens, and you either get a big spark, or smoke, the wire should not be grounded.
Old 11-18-2005, 05:07 AM   #3
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
buckaroo
first, welcome to the forum.
yes the blue wire runs your jack, reconnect it and it should work.
as for the "solenoid" are you sure it is not your break away switch? does it have a hole in the front of it?
john
you call them ferrets, i call them weasels.
Old 11-18-2005, 08:27 AM   #4
Thank you so much for the quick response. I'll be sure to connect the blue wire and go from there. I'll also look more into the "solenoid/break away". Thanks again. This airstream forum idea is great!
Old 11-18-2005, 10:14 AM   #5
Well Preserved
1993 21' Sovereign
The breakaway switch is for the trailer brakes, in case the trailer comes unhitched from the tow vehicle. The force of this happening will pull a lanyard,(available from most trailer supply places), which will apply the trailer brakes, stopping it quickly, and (hopefully) without injuring anyone around.
Another Power Jack Question. 68 Suburban Jacks, Stabilizers, Lifting and Leveling 3 10-15-2002 10:23 PM
Power Jack Question 68 Suburban Jacks, Stabilizers, Lifting and Leveling 3 10-11-2002 06:05 PM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Electr. Tongue Jack Wiring?? roessler Jacks, Stabilizers, Lifting and Leveling 12 07-17-2002 11:00 AM
Jack Resync jcanavera 2001 Safari 1 07-03-2002 10:45 AM
