Due to own stupidity a few days ago I had no power to my electric jack. After correcting my little screw up the jack worked fine. It got me thinking about how I would raise or lower the jack if it did go out. Following the instructions in the jacks manual I removed the top and located the manual control nut. I made sure I had the proper tool to use in my tool bag. I did not want to screw with the gear timing so did not actually raise and lower. But at least I know I can if the need arises.
MICHAEL
