Old 07-24-2010, 03:12 PM   #1
Newberry , Florida
Who's the mfg?
1973 Overlander 27'
Not sure this is the original, but I got it working (in only one direction). Any idea who the manufacturer is so I can attempt to replace the broken shroud and switch?
Photos attached
Overlander is offline   Reply With Quote
Old 07-24-2010, 03:23 PM   #2
Mexray's Avatar
1978 28' Ambassador
Morada , California
Why mess with it? That old a unit is bound to be worn out...that's one of the first things I replaced on our 78...
You can usually find these tongue jacks on special from any number of RV parts outlets - it's a popular item...
Get one with excess capacity, so it won't be working all that hard when you use it - and it will last longer as well...
You might want to get a new break-away switch as well, they are cheap, and good insurance in case you need it!
Good luck on your project...
Ray
Ray & Pat; Morada, CA
Old 07-24-2010, 03:35 PM   #3
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
That is a REESE tongue jack. Not sure if there are any limit switches in that one. The one I had I had to replace the switch DPDT center off. They were available from reese 10 years ago. The jack is quite old and was probably put on by the original owner
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 07-25-2010, 08:42 PM   #4
Newberry , Florida
Thanks for the info. It works fine, the shroud is only cosmetic and to work in the opposite direction, I can just reverse the wires. I was hoping for $20 or $30 bucks I can replace both. Afterall, this project is going to be my home at the hunting camp in Georgia so I'll just need the jack twice...once there and once back. I suppose a new one is not economical considering it's use.
Old 07-25-2010, 08:56 PM   #5
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
You may be able to get a replacement switch at your local Auto Parts store.
Those switches are used in many applications.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 07-31-2010, 06:02 AM   #6
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
That swith will carry a lot of current. So get a HD one if buying genaric.
>>>>>>>>>>Action
