Old 10-17-2016, 10:03 PM   #57
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Where to place level in camper to get truest reading
A fridge operates fine on roads because of the constant motion which keeps things moving.
Half a bubble off is not an issue. Leveling is easy as long as you know that the device you are using, or the surface you are measuring from is level. That's why one time only when I get a trailer for the first time, I get really anal to get as perfect a level I can. Then I can verify if the leveling appliance that the dealer installed was done right. If not I fix it and there after use it to level.
Jack Canavera
STL Mo.
AIR #56
What level and where to place it ?? MOS General Repair Forum 10 03-11-2016 05:08 PM
Replace "Reading lights" with real reading lights and fans? Belbein Airstream Lifestyle 0 06-08-2014 12:30 PM
control panel gauge not working , get reading on probes batt Electrical - Systems, Generators, Batteries & Solar 2 08-22-2013 07:38 AM
to level or not to level urnmor Jacks, Stabilizers, Lifting and Leveling 23 07-30-2012 11:21 AM
How level is level? RichardT 1961 - 1963 Bambi 7 03-12-2006 03:52 PM
