Old 10-10-2016, 08:41 PM   #43
2015 30' FB FC Bunk
2012 25' FB Flying Cloud
Golden , Colorado
Last one was broken by road debris.
2015 30' FC Bunk, Dual A/C, Full Awning, RV550, Sleep Number, ProPride, Nokian Rotiiva AT 15" Tires
2015 Chevrolet 2500HD 4WD Duramax/Allison LTZ Crew Cab Short Bed, Huper Optik, Bull Dog Spray In, Roll-N-Lock, Full Amsoil, Denali SoundBomb, Yakima
2012FB is offline   Reply With Quote
Old 10-10-2016, 10:47 PM   #44
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
Lay a Torpedo level on the outside of the screen of an open window then close the window if desired. Leave it forever. Be sure an use a window closest to the wheels.
That way you are not being influenced by frame twist from leveling. Also use a large RV level bolted to the front rock guard so that you can see it when pulling on a parking spot. This procedure will be the fastest way to level up. Using the floor over the wheels would be good, but your weight will influence the level accuracy. Counter tops are notorious for not being installed perfectly level in relation to the frame during the original build.
guskmg
Old 10-15-2016, 07:45 PM   #45
2015 30' FB FC Bunk
Golden , Colorado
Originally Posted by 2012FB View Post
Thanks Joe!! I am on the notification list.
They are now in stock at Amazon. Got one coming my way.
Old 10-16-2016, 04:14 PM   #46
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Looked up the LevelMate Pro on Amazon, which then also mentioned the ReVo leveler.
Has anybody tried the ReVo leveler? If so, wondering whether you liked it. Seems similar to the LevelMate Pro, minus the bluetooth. Surprisingly, it's a little more expensive but I like the ability to charge it from a 12V outlet vs. buying more batteries.
http://www.revoleveler.com or https://www.amazon.com/gp/product/B00V8RRIKE
Rocinante is our 2014 International Signature 27FB
Old 10-16-2016, 05:27 PM   #47
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
Originally Posted by tevake View Post
I also use the kitchen counter, but have read here and agree that the really critical spot to level is the stove top.
Do all of your eggs end up on one side of the pan?
See its critical , roll out of bed meh, piled up eggs unacceptable.
Cheers Richard
Have to agree on that one. I usually forget about it though when I am setting level and when it comes time for my eggs I realize I've done it again. Rats!
George
gandttimes is offline   Reply With Quote
Old 10-16-2016, 05:44 PM   #48
Rivet Slave
Rocinante's Avatar
Our Airstream dealer says that if you operate your fridge while stationary and off-level, you're risking that fridge going "kerflooey." He further says that if your fridge goes on the fritz because of this, the fix is quite expensive.
So, if I have to choose between leveling the eggs or the fridge, I'm choosing the fridge.
Old 10-16-2016, 05:54 PM   #49
gandttimes's Avatar
2007 20' Safari SE
2005 19' Safari
Haven't had an issue with my fridges in 19 years but I've messed up some eggs😆
Old 10-16-2016, 10:05 PM   #50
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Yep, pretty much why I measure from the floor of the freezer with a round bubble level and then use that to set up the level mounted on the trailer. Setting from any other point without correlation makes the assumption that the fridge was installed level at the factory. But as we all have seen, assuming everything is done correctly on a hand built trailer has been proven to be fleeting.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 10-17-2016, 11:33 AM   #51
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
I use the bubble level on my iPhone. I place the phone on a stove burner. With that level, everything else is very, very close, some things are right on. I cook a lot. Works for me.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 10-17-2016, 12:26 PM   #52
richw46's Avatar
Lexington , Kentucky
If the fridge can operate on the road going uphill, downhill, around curves and deal with roads that have a strong crown for getting water off the road, why does it have a problem in the campground where it's sitting still and a half bubble off plumb? Traveling on the Interstate you'll see the road is not flat and level but slopes to the left or right to eliminate rain water. Why isn't this a problem for the Dometic if you're traveling with it on?
When backing our AS into our site I've asked my wife if she would hop out and fry a couple of eggs on the stove to ensure we were level. She says our little bubble level is just fine. (She really said something else but I'm going with the above statement instead.)
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 10-17-2016, 12:34 PM   #53
AStreamNerds's Avatar
2015 25' FB Flying Cloud
Manassas , Virginia
I just received my LevelMate from Amazon yesterday and hope to try to install it this coming weekend. Looks easy enough - I am going to install behind drawer in center night stand on our FB. It is wood and should be no issue attaching to the wood backing of the cabinet with the drawer out.
I am going to follow the advice here and use the fridge as my level guide although I normally use the kitchen counter with an 8" level when camping.
You Tube Channel "Airstream Nerds": https://www.youtube.com/airstreamnerds
Find Us on Facebook: https://www.facebook.com/AirstreamNerd/
AStreamNerds is offline   Reply With Quote
Old 10-17-2016, 12:46 PM   #54
Long Island , New York
Yes, the newer Dometics are designed to accommodate all those out-of-level conditions temporarily, but not a seriously tilted permanent home. To repeat the advice in Post #33, if the trailer feels level to you as you walk around inside, it is level enough for modern Dometic fridges.
Our owners manuals say this also BTW, not that anyone takes the time to check usually . . .
You can get some wife-credits by telling her she is right -- that the bubble level is accurate enough (assuming it has been calibrated correctly). I just put a small torpedo level inside the entry door when unhitching.
People tend to way over-think this IMO.
Peter
Old 10-17-2016, 01:23 PM   #55
richw46's Avatar
Peter
Our Airstream travel rules:
Rule #1: Momma is always right
Rule #2: If it should ever occur that momma is wrong, consult rule #1 immediately.
I agree, Peter, this leveling thing is way over analyzed; analysis paralysis. There have been some good ideas here but I'm sticking with my little bubble level on the counter and lack of fridge door movement. Everything in your trailer is designed with the consideration that some people aren't going to pull out a carpenter's level every time they park.
Except for some scientific instruments, most appliance will work if not perfectly level. My brother had a house where he could put his bowling ball by the back door and let it go. It would eventually roll out the front door. The fridge, washing machine and dryer all worked fine for the 8 years they lived there. He does lean to the right and his wife to the left, not sure if the house had anything to do with that or not.
-Rich
Rich & Yvonne
2004 4Runner SE
Old 10-17-2016, 08:41 PM   #56
1988 32' Excella
Robbinsville , New Jersey
I was told that the problem with the fridge not being level is that the coolant in the fridge can pool and act as a clog. Not sure about where you drive but, most roads I drive on have bumps and/or turns which actually help keep the circulation going in the fridge.
What level and where to place it ?? MOS General Repair Forum 10 03-11-2016 05:08 PM
Replace "Reading lights" with real reading lights and fans? Belbein Airstream Lifestyle 0 06-08-2014 12:30 PM
control panel gauge not working , get reading on probes batt Electrical - Systems, Generators, Batteries & Solar 2 08-22-2013 07:38 AM
to level or not to level urnmor Jacks, Stabilizers, Lifting and Leveling 23 07-30-2012 11:21 AM
How level is level? RichardT 1961 - 1963 Bambi 7 03-12-2006 03:52 PM
