Old 10-09-2016, 08:58 PM   #29
Len and Jeanne
Len n Jeanne's Avatar
2005 16' International CCD
2015 19' Flying Cloud
Creston Valley , British Columbia
When in doubt, just put some water in your sinks. See which way it tilts or if it's level.
Len n Jeanne is offline   Reply With Quote
Old 10-09-2016, 11:13 PM   #30
2015 30' FB FC Bunk
2012 25' FB Flying Cloud
Golden , Colorado
Anyone know of a level that will connect Bluetooth to an iPhone? I would like to monitor the side to side level from in the truck using my iPhone as the remote display as I pull on to the leveling ramps and then at the tongue for front to back.
2015 30' FC Bunk, Dual A/C, Full Awning, RV550, Sleep Number, ProPride, Nokian Rotiiva AT 15" Tires
2015 Chevrolet 2500HD 4WD Duramax/Allison LTZ Crew Cab Short Bed, Huper Optik, Bull Dog Spray In, Roll-N-Lock, Full Amsoil, Denali SoundBomb, Yakima
2012FB is offline   Reply With Quote
Old 10-09-2016, 11:17 PM   #31
CRH
1995 25' Excella
xxxxx , xxxxxx
I use a 4" Hopkins level on the front of my trailer for side to side leveling while pulling up on my Anderson levelers. I can easily see the bubble from my TV. After unhitching, I use a level on the fridge's freezer plate to level front to back.
CRH is offline   Reply With Quote
Old 10-10-2016, 06:40 AM   #32
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
On the entry door sill is where the mechanics at Jackson Center recommend placing the level for front to back leveling.
I usually place the level on the propane tank cover for side to side leveling if it is even necessary. Most of the time I either don't level side to side or eyeball it. Usually it is leveling blocks on the street side only. Maybe campsites have a crown like a roadway and I get all the way on the edge of the street side?
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 10-10-2016, 06:47 AM   #33
Long Island , New York
Modern AS fridges do not need to be as level as the old ones. Owners manual covers.
If the trailer feels level as you walk in it, it is level enough! Per earlier comments a small torpedo level or iPhone etc. on the floor just inside the entry door is easiest, as you can stay on the ground and quickly return to the tongue jack to adjust height.
Avoid analysis paralysis . . .
Old 10-10-2016, 07:25 AM   #34
jayseejay's Avatar
2015 27' FB Eddie Bauer
2011 25' FB Flying Cloud
Fernandina Beach , Florida
LevelMate Pro, but they are currently out of stock. Joe
http://www.command-electronics.com
jayseejay is offline   Reply With Quote
Old 10-10-2016, 02:24 PM   #35
1996 25' Excella
Tillsonburg , Ontario
As most of us have discovered, level is relative. Counters don't always follow the floor or even one another. Fridge level is a non issue for the small outage it might see. Mine works fine up to two inches off level during travel, although that might be due to bounce and roll of the trailer. It has always worked with a half inch of tilt side to side.
I make sure my sink counter is level. That way a bit of water escaping the sink/tap doesn't run away before I get it mopped up. An inch or so out of level front to back won't be noticeable by the fridge or your bed, but water will sure run down hill.
JCW
JCWDCW is offline   Reply With Quote
Old 10-10-2016, 03:36 PM   #36
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
Is it a twin model?
Several folks have same method we use for leveling; floor inside door. I have front twin beds, and even when I start out with head being up slightly, when I drop my rear leveling jacks, I loose a little height in the front, even thought front leveling jacks are down, so I compensate a little by making sure front is a little higher when first setting up, and don't crank the rear stabilizing jacks so much. (also, I use a Ryobi drill with 3/4" socket to make this task go fast!)
Another question is if you have twin beds? If so, there was a thread stating that the twin beds are built, angling toward the center. We notice this in ours, even when level front to rear and side to side. A few folks have mentioned a fix, adjusting with wood or some material under the mattress. Don't remember exactly what they used or how much.
Old 10-10-2016, 04:19 PM   #37
2015 30' FB FC Bunk
Golden , Colorado
Thanks Joe!! I am on the notification list.
Old 10-10-2016, 05:33 PM   #38
DoublTrouble's Avatar
2015 27' FB International
Carlsbad , California
Old habit. Small, round bubble level on floor in front of fridge.
DoublTrouble is offline   Reply With Quote
Old 10-10-2016, 05:50 PM   #39
2015 28' Flying Cloud
Newtown , Pennsylvania
My shower won't drain unless I lower the front a bit.
Bruce
50 amp, Awning package
2015 Ram 2500 6.7 TD, Blue Ox 1000 lb.
4 Lifeline AGM, Trimetric 2020
PD9160 converter, Prosine 1800 inverter
2x eu2000i Propane
AstroBruce is offline   Reply With Quote
Old 10-10-2016, 06:04 PM   #40
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Think yer pretty smart hah?
MelGoddard is offline   Reply With Quote
Old 10-10-2016, 06:09 PM   #41
Why???? Just get one of those 'bubble' or 'ball' levels, that stick on the front of the trailer. They are stick-on and/or screw ons.
You level the trailer laterally and then install and adjust as required.
When going into a spot, just look in the rear view mirror, and watch for that magic level spot. Easy peasy!
Old 10-10-2016, 06:35 PM   #42
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Our Airstream dealer's service manager emphatically agrees that the best way to level your trailer, when using your fridge, is to put a bubble level in your freezer and get it to read level. This is because it is often true that the fridge isn't quite level with the floor, and the fridge is more sensitive to being level than you are.
Rocinante is our 2014 International Signature 27FB
What level and where to place it ?? MOS General Repair Forum 10 03-11-2016 05:08 PM
Replace "Reading lights" with real reading lights and fans? Belbein Airstream Lifestyle 0 06-08-2014 12:30 PM
control panel gauge not working , get reading on probes batt Electrical - Systems, Generators, Batteries & Solar 2 08-22-2013 07:38 AM
to level or not to level urnmor Jacks, Stabilizers, Lifting and Leveling 23 07-30-2012 11:21 AM
How level is level? RichardT 1961 - 1963 Bambi 7 03-12-2006 03:52 PM
