Old 10-09-2016, 01:18 PM   #15
2015 30' International
FREDERICK , Maryland
Originally Posted by J. Morgan View Post
I level on the floor inside the entry door on the floor using a level app on my iPhone....
I do this or we keep a bubble level in that small cabinet space under the stove.
Doc Foster is offline   Reply With Quote
Old 10-09-2016, 01:32 PM   #16
1977 31' Sovereign
Lynnwood , Washington
For fine-tuning, I use an ordinary, 24" carpenter's level: across trailer tongue; rear bumper; place level flush under each window frame. As far as I'm concerned, if the bubble touches either line on the level, it's is "good enough."
But if you're rolling out of bed, perhaps you should level your bed instead of your rig. LOL
Seriously, an unlevel bed is worth checking in to. In this business, stranger things have happened.
Tom
TomKirk is offline   Reply With Quote
Old 10-09-2016, 02:52 PM   #17
Cruiser6483's Avatar
1954 25' Cruiser
Bern - Thun , Berner Oberland
Images: 30
I like it convenient, lol... My computerized hydraulic system:
www.ep-hydraulics.nl/en
Greetings from Switzerland - Werner
Cruiser6483 is offline   Reply With Quote
Old 10-09-2016, 03:04 PM   #18
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
On my 30' FC, I put a torpedo level on the freezer floor, and jacked up the nose till level.
I then set two bubble levels, (One on each A-frame arm) to match the torpedo level.
When the nose is jacked up to level, the whole 'house' sits several degrees nose high, but that's all right. The eggs don't slid to one side of the pan, and the bed is very comfortable. (I store the AS on a level pad that I had poured out back.)
For lateral (East-West) leveling, I have one those 'steel ball in a tube of fluid' affairs mounted under the front window. It works.
Just Two 'Trailer Trash' living in a 'Tin-Can Shack'.
"Look after your Equipment, it'll look after You."
MelGoddard is offline   Reply With Quote
Old 10-09-2016, 03:07 PM   #19
greenflag's Avatar
2016 30' International
Quartz Hill , California
Torpedo level on freezer floor
greenflag is offline   Reply With Quote
Old 10-09-2016, 03:07 PM   #20
1988 32' Excella
Robbinsville , New Jersey
That is nice.
HUGE problem though, Airstream trailers are not stiff enough to handle being leveled that way. It would twist the body, possibly causing problems such as leaks and not being able to close the door.
Old 10-09-2016, 03:40 PM   #21
1954 25' Cruiser
Images: 30
Wazbro
My Cruiser has a new stronger chassis. The driving permit for the trailer is on a total weight of 3 tons. So far, he has not yet fallen apart....
Old 10-09-2016, 03:47 PM   #22
2005 28' International CCD
Camarillo , California
Best reply, once you have the coach level fix the level on top of the jack.
loft47 is offline   Reply With Quote
Old 10-09-2016, 04:06 PM   #23
2000 30' Excella
2014 30' Classic
Princeton , Iowa
I have a cheap 1 ft. carpenters level in my storage compartment. I use the rub rail and have checked it v/s the floor and they are the same. It is easy, right where you are working. The little bubble level on my jack is off.
larryglarson is offline   Reply With Quote
Old 10-09-2016, 05:25 PM   #24
New Borockton , Alabama
Images: 21
That was the first thing that came to my mind lol heck with the fridge being level
Randy...Converters, Inverters, Trimetric, Surge Protectors, Zamp Solar, AGM Batteries
www.bestconverter.com
Old 10-09-2016, 06:07 PM   #25
80Ram's Avatar
2017 25' Flying Cloud
Scott City , Missouri
We have a 2017 Flying Cloud 25FB and I have the same sliding out the bed feeling. I always level the trailer inside the front door with a 2' level and check the fridge with a 6" level. Guess next time I'll put a level on the beds plywood frame and check it. I am wondering if the mattress overhanging the plywood has something to do with it, causing a gravitational pull. I would hate to cut off the overhang and find out that wasn't it.
80Ram is offline   Reply With Quote
Old 10-09-2016, 06:09 PM   #26
Nomad518's Avatar
2001 25' Safari
Vancouver , Washington
Originally Posted by Tincampers View Post
Ditto on the floor. Modern fridges are not that sensitive to an out of level condition. If you are comfortable then the fridge should be fine. The iPhone app works great. You'll find it with the compass app. Slide left or right and it'll change to the level app.
Thanks for the iPhone tip. Didn't know the level function was there. I've always used a 9" Stanley level we carry onboard. We're camping right now at Silver Falls State Park in Oregon. I used the iPhone app to double check my work with the Stanley level. Spot on. I guess that's why neither my wife or I rolled out of bed onto the floor last night! 😊
Nomad518 is offline   Reply With Quote
Old 10-09-2016, 08:01 PM   #27
Barbieri's Avatar
2004 30' Classic
San Antonio , Texas
It is better than the comedy hour. One simple question and over twenty different answers. Just use a simple leveler placed inside the AS door and then adjust trailer. I then check the shower door open. I am not paranoid about being level to centimeters. I say close enough for government work.
Barbieri is offline   Reply With Quote
Old 10-09-2016, 09:31 PM   #28
Gold Country , California
Welcome to the comedy hour!
NorCal Matt is offline   Reply With Quote
What level and where to place it ?? MOS General Repair Forum 10 03-11-2016 06:08 PM
Replace "Reading lights" with real reading lights and fans? Belbein Airstream Lifestyle 0 06-08-2014 01:30 PM
control panel gauge not working , get reading on probes batt Electrical - Systems, Generators, Batteries & Solar 2 08-22-2013 08:38 AM
to level or not to level urnmor Jacks, Stabilizers, Lifting and Leveling 23 07-30-2012 12:21 PM
How level is level? RichardT 1961 - 1963 Bambi 7 03-12-2006 04:52 PM
