Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Jacks, Stabilizers, Lifting and Leveling
Old 12-02-2006, 11:08 PM   #15
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 60
Jack stands should be placed at the mounting plates as well, but that is not how I would do it. It would be alot safer and easier to build ramps out of 2X6's and tow the trailer onto the ramps. Chock the wheels when they are on the ramps and you are set. I have a 2 sets of Lynx Levelers that let me build ramps for leveling when camping. They are lego type blocks and they work great also.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 12-02-2006, 11:42 PM   #16
2airishuman
2airishuman's Avatar
Profile:
hi bean...
i'm with azf' on this...
use ramps AND chocks....
very secure and stable....
jacks or blocks could be added at the out riggers for stablity.
i've raised my on one side 10 inches or so...
i've got a set of the 12k version here...
http://www.blitzusa.com/automotive/ramps.html
if you've read all the threads, then you've seen those great pictures of the bottle jacks, under the axle plates....
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 12-02-2006, 11:46 PM   #17
azflycaster
Phoenix , Arizona
Images: 60
Don't do this!
Richard
Old 12-02-2006, 11:54 PM   #18
urbanfood
urbanfood's Avatar
Profile:  1956 22' Flying Cloud
Venice , California
Originally Posted by azflycaster
Don't do this!
i wonder how close he is welding to the gas tank.
david
*by asking the above question,
i verify that i have already used
the search feature to the best of my ability...
urbanfood is offline   Reply With Quote
Old 12-02-2006, 11:56 PM   #19
Fyrzowt
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
Keeps me employed...!!!
Fyrzowt is offline   Reply With Quote
Old 12-02-2006, 11:59 PM   #20
azflycaster
Phoenix , Arizona
Images: 60
I had to look at your profile to get that one, I thought maybe you were an undertaker .
Richard
Old 12-03-2006, 12:00 AM   #21
Fyrzowt
Fyrzowt's Avatar
Images: 8
There are times when I feel like one.
Old 12-03-2006, 01:16 PM   #22
shinybean
shinybean's Avatar
Profile:  Greenville , South Carolina
Thanks for the tips. It's good to know the right way to do something...
shinybean is offline   Reply With Quote
Old 12-03-2006, 02:14 PM   #23
SmokelessJoe
SmokelessJoe's Avatar
Profile:  1976 Argosy 24
TORONTO and Southwestern , Ontario
Shinybean:
You have the right idea. Jack it up at the axle mounting plates.
You can insert I beams, plate-to-plate, and use jack stands.
You can also weld up support frames if you are going to being doing extensive work under the trailer.
That is the way we did it. Photos below explain.
Sergei
SmokelessJoe is offline   Reply With Quote
Old 12-04-2006, 01:41 PM   #24
Easyriser
Profile:  1996 30' Excella
Burlington, Ont. Canada , Ontario, Canada
Jaking up the Trailer
I have recently purchased a 1996 AS 30 Ft Excella. Can anyone assist with the size of pole jack to change a tire? They are sold in 2,4,6,8 ton etc. My GVW is 8300 Lbs. I was thinking of a 6 ton. I am aware of the AS method of using 2X8 boards but wanted to get a jack just in case.
All the best,
Easyriser is offline   Reply With Quote
Old 12-04-2006, 04:38 PM   #25
SilverToy
Profile:  1992 34' Limited
Falls Church , Virginia
Jacking issues and more....
Hi Easy!
Welcome! Hope that your 'new to you' AS gives you as much joy as nearly everyone here gets out of thier units!
As to jacking, for tire replacement, bearing work, or whatever - be sure to use the 'Search' button in the upper right corner, as there is a LOT to know about jacking AS's, and just as much to know that is WRONG about jacking AS's...!!! Knowing the particulars can save a lot of time, aggrivation and $!!!
I would say that a 6T should easily handle nearly all your AS jacking needs, but then a 8T is only a few $ more, not significantly larger, and can certainly handle anything that the 6 could do and then some..... Not that more is better!?!
Just be sure that you know where to jack and then do it safely! Enjoy.
Axel
SilverToy is offline   Reply With Quote
Old 12-04-2006, 05:51 PM   #26
markdoane
Profile:  , Minnesota
Images: 59
I would try to test the bottle jacks before you buy. Sometimes they have the same size pump and different size hydraulic cylinders.
This means the larger capacity jacks require a lot more pumping strokes to raise the jack the same distance. That and the fact that the larger jacks are heavier and harder to muscle around leads me to recommend you get the smallest one that will do the job.
Under ideal conditions, I think a 2T will probably work. Get the 4T to be sure.
Non-contributing deadbeat.
Old 12-04-2006, 05:55 PM   #27
LI Pets
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
Ok, you are only jacking one part of the weight, take off the tongue wgt - 1,000, 7300 lbs lifting one side 3650.
so a 2 ton is plenty.
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper | Airbags
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
Old 12-05-2006, 07:47 AM   #28
Easyriser
Many thanks folks. Your guidance is much appreciated.
voltage for electric jack maznblu Towing, Tow Vehicles & Hitches 3 04-16-2004 09:32 PM
removing electric jack CHRIS CANNON Our Community 0 09-30-2002 07:51 PM
Bent Trailer Door Argosy74 Doors & Locks 3 09-03-2002 09:31 AM
New years added to Trailer Forum 83Excella Our Community 3 07-08-2002 07:24 AM
