Old 12-23-2012, 11:07 AM   #1
Lothlorian's Avatar
Loganville , Georgia
Where to Jack up my 1960 Overlander with leaf springs
I know where to Jack up my 1973 Overlander (between the tires). The 1960 has Leaf springs and I was wondering where to Jack it up to remove my tires and wire brush/por15 my wheel wells. I was wondering if I do it between the tires like the 1973,
Where would I put my Jack stands for safety?
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 12-23-2012, 01:33 PM   #2
Lothlorian's Avatar
I am bringing this thread forward again before it leaves the portal. I have hadco axles on it and I hope they are in good shape.
Brian
Brian & Adrienne
Old 12-23-2012, 01:53 PM   #3
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
With leaf spring axles, where to jack it depends on what you want to do. If you only want to get one wheel off the ground, I would jack it under that axle close to the wheel. If you wanted to get the whole side off the ground, I would jack directly on the frame. I would use ramps, if I wanted to get one axle (and its two wheels) off the ground.
1960, 1960 overlander
