Old 04-11-2008, 07:49 PM   #29
gunnyusmc
Gunnyusmc's Avatar
Livingston , Texas
Images: 69
Chokes
Try Rotochok.
Gunny
Gunnyusmc is offline   Reply With Quote
Old 04-11-2008, 08:19 PM   #30
wheel interested's Avatar
2007 23' International CCD
Lapeer , Michigan
How do the wheel locks stabilze the trailer movement, if someone doesn't mind educating me? That sounds like a big plus. If the air is let out of the tires do they slip off? We use lynx levelers and plain rubber chocks that we have used for years since our first trailering days and a simple padlock on the hitch which we realize is not securing the unit against theft.
Caroljb
photography
wheel interested is offline   Reply With Quote
Old 04-11-2008, 09:18 PM   #31
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
Carol: with tandem wheels, the facing surfaces of adjacent tires want to go in opposite directions ... that is, if the trailer is moving forward or trying to, the forward surface of the rear tire is going downward, while the rearward surface of the front tire is going upward. The between-the-tire chocks take advantage of this relative motion by wedging in between the tires and preventing it. Then the wheels can't roll. No roll, no trailer movement. No trailer movement, happy camper! I'm sure if you lost enough air, even rotochocks would fall out, but as someone else said earlier, if that much air is lost, you've already got BIG problems!
AirsDream is offline   Reply With Quote
Old 04-11-2008, 09:40 PM   #32
Lapeer , Michigan
Thanks AirsDream! Karma going your way! I like stability!! I wonder if I could get by with a do it yourself cheapie or just should bite the bullet and buy yet another little something for the AS.
I didn't mean my tires would be leaking that badly, please NO! I meant that I wondered if someone could let the air out, remove the chock and then use a compressor to refill the tires, if someone was depending on the chock for remote area security.
Caroljb
photography
Old 04-11-2008, 10:58 PM   #33
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Devices which prevent the trailer from moving are an important safety item. A/S and other high end types should have something like rotochok standard. It is not just a matter of campground convenience, but when making an unscheduled stop on the shoulder for reasons one cannot plan for.
Just like having D.O.T. triangle reflectors and some flares, good chocks are a necessity.
The strongest "ordinary" chock are the type sold to prevent tractor-trailers from rolling; big, heavy, ribbed rubber triangular shaped ones.
The 815# style is what I carried as an OTR driver (required by some companies, just like hard hat, steel toes, etc)
Checkers® Industrial
I keep some old aluminum lever-style chocks that I can lock, on the trailer; they're hard to remove once placed. In the back seat of the TV I keep the BAL chocks shown above. I'd have bought the rotochoks had I known of them.
Hensley Arrow. 9-cpm solo, 15-cpm towing
Old 04-11-2008, 11:44 PM   #34
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, Ford Truck. I use the same ones that you mentioned and like the way they work.
Originally Posted by kamadeca
The only problem I see with the Rotochuks is you loose effectiveness if the tire(s) loose pressure. If you loose enough pressure the chock would fall out and who knows where your trailer is going to end up. Anyone have this experience?
Hi, kamadeca. This could be true, but I use two chocks; This would mean that I would have to get one low tire on each side of my trailer at the same time. [not likely to happen]
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 04-14-2008, 08:22 AM   #35
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
Carol makes an important point if you are using the rotochocks for security. Even the new models with the ability to add a pad lock would be less effective if someone let enough air out of the tires, I think. On the other hand, would the tire slump and expand laterally to keep pressure against the rotochock as the air was released or would it allow the rotochock to become loose and be removed? BTW, as I mentioned before, I drove off with one set left in the road side tandom and I ran over it as I was pulling out so I'm not sure how good they would be at preventing theft. (I have a stump pulling diesel, though.) I think the pad lock would be more to prevent the rotochoks from being stolen, not the trailer.
I apply just enough pressure to stabilize the trailer. I realize that I'm not going to be applying as much pressure in one spot with the rotochocks as the weight of the trailer bearing down on one spot on the ground, but I still worry about making the tire get out of round if the pressure from the rotochock is applied for too long such as while stored between trips...something I don't think Carol has to worry about...that woman doesn't let moss grow beneath her feet before she is off again!
Family of Disney Fanatics
WBCCI# 4821
Old 04-14-2008, 09:43 AM   #36
2006 30' Safari
Orlando , Florida
I just got an e-mail ad from Camping World. They are having a big sale and one of the "Top 25" items they have on sale is the "Deluxe Tire Locking Chock" for $44.99. I think that is what I paid for mine last fall. I was waiting specifically for them to go on sale since they usually do so twice a year. BTW, this is the price for one chock. You will need to order two at this price, each, if you want one for each side of the coach.
WBCCI# 4821
Old 04-14-2008, 11:00 AM   #37
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Rivet Other Alternatives
Here are a couple of solutions I spotted at the October Branson rally.
ID:	58229   Click image for larger version
Vaughan
Old 04-14-2008, 11:06 AM   #38
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Now I like that first one made from wood - guess I'll be in the garage tonight......
Thank You - those I can afford.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 04-14-2008, 11:51 AM   #39
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
Originally Posted by Minnie's Mate
Do you also wear suspenders with your belt?
OK, let me get back up off the floor..
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 04-14-2008, 01:39 PM   #40
markparker22's Avatar
1984 31' Excella
Santa Barbara , California
Chatham Chocks
I bought a pair of chocks via ebay. I do not see them listed now but here is an email address for Chatham Chocks: kbakker@tds.net
Price was $35/pair plus shipping $30. Price was reasonable and no extra tools needed.
Mark
1984 31' Excella, mid bath, king size bed
1998 Chevrolet Suburban K2500, 7.4L/454 c.i., 4WD, Pullrite Hitch
AIR No. 2375
"You know... life is just the way it is...."
markparker22 is offline   Reply With Quote
Old 04-14-2008, 01:52 PM   #41
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Oh....
Originally Posted by Lumatic
For edification of other stubborn old farts, and the younger ones too
#1 Ruined a perfectly good aluminum between the tires chock that came with my 73 by not checking it was removed before driving off. They hold good.
#2 Figuring I don't really need chocks anyway, unhitched on a very slight incline without chocking. And yes, those aluminum wheely thingys that fit on the bottom of your jack really do roll good. Picture me thinking I could stop a 5000# trailer in motion by grabbing hold of the A frame. No damage other than the split in the seat of my pants and ego, but slid off into a ditch and took a good deal of jacking with a bottle jack to get her hitched up again.
Not to spoil your day, but there is the emergency trailer BRAKE pin.... just pull it out by the wire...
Uh... nevermind.
Old 04-14-2008, 11:44 PM   #42
Salem , Oregon
Images: 18
Hi, I do think that in the picture with the yellow chocks, blocked between the wheels, you don't have to worry about them slipping out of place. [good idea]
2005 Safari 25-B
Wheel Bearing Adjustment Dwight Axles 9 05-15-2008 06:50 AM
Wheel Chocks pjtaia On The Road... 13 10-28-2005 03:27 PM
Wheel Bearing?? - - or - - Brakes?? overlander64 Axles 8 11-24-2002 01:13 AM
Wheel Bearing Temperature Road Ruler Axles 23 10-16-2002 09:54 AM
The Junkyard Wheel Story Inland RV Center, In Wheels, Hubs & Bearings 1 04-10-2002 07:04 PM
