Old 11-28-2014, 02:01 PM   #43
aircampr's Avatar
2015 23' International
Lake Forest Park , Washington
Images: 21
Originally Posted by PharmGeek View Post
those fastaway ones look nice...I think I may upgrade if santa will bring them...look pretty solid...
The anderson thingies interested me, but now 3 times in my camping in my first year I have needed more elevation than that to make things level...I keep two backs of those lynx level blocks...
I need to figure a system for looking at my level and knowing exactly how many blocks stacked I need...NEVER have I got it right the first try...usually by the 3rd....*ARGH*
Use these bubble levels:
RV Levels, Set of 2 - RV Designer E401 - Levels - Camping World
One Lynx leveler block is 1.25 divisions on the scale. Two blocks, 2.5, etc. we marked the scale on the lateral level with white nail polish. Works first try every time. If the ground is uneven, you may have to back up and stack the blocks where the tires were sitting when you checked the kevel.
Cheers,
Charlie
aircampr is offline   Reply With Quote
Old 11-28-2014, 02:19 PM   #44
aircampr's Avatar
Images: 21
Will Anderson levelers work to change a tire? The ones I saw were only 4" lift, and the AS manual says use 8" lift to change tire.
Is anyone using the Anderson levelers with a recent 23D? I can't find specs for axel spacing.
Charlie
Old 11-29-2014, 01:50 PM   #45
aircampr's Avatar
Images: 21
Correction...
Charlie
Manual says raise 6" to change a tire.
Who uses tandem wheel chocks? Splitrock Brakes & Brake Controllers 47 08-26-2014 09:20 PM
Fastway ONESTEP Wheel Chocks jcanavera Jacks, Stabilizers, Lifting and Leveling 5 10-03-2009 06:14 PM
Aluminum wheel chocks MW64OVERLANDER Jacks, Stabilizers, Lifting and Leveling 5 09-01-2008 09:58 PM
Wheel Chocks FordTruck Jacks, Stabilizers, Lifting and Leveling 42 04-18-2008 02:30 PM
Wheel Chocks pjtaia On The Road... 13 10-28-2005 02:27 PM
