Old 11-03-2014, 12:27 PM   #41
SteveH's Avatar
Common Sense , Texas
Originally Posted by crispyboy View Post
A question for those who own the Anderson Leveling System, will these work in conjunction with the type of wheel chock shown above?
If the trailer only needs a minimum rise will they conflict with the wheel chocks?
The Andersens do not prevent the use of the wedges between the tires, but if you use the Andersens you do not need to use anything else on that side, assuming you are not parked on a 10 degree incline.
Regards,
Steve
Old 11-27-2014, 10:28 PM   #42
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Well, I went to Amazon to look for the Fastway Onestep Chocks and there are three different models - apparently you choose based on how far apart the axles are... but very little real information.
Sigh....
Watched the video and chose the one with the shortest span (16" Michelins on the EB)
Paula
Old 11-28-2014, 02:01 PM   #43
aircampr's Avatar
2015 23' International
Lake Forest Park , Washington
Images: 21
Originally Posted by PharmGeek View Post
those fastaway ones look nice...I think I may upgrade if santa will bring them...look pretty solid...
The anderson thingies interested me, but now 3 times in my camping in my first year I have needed more elevation than that to make things level...I keep two backs of those lynx level blocks...
I need to figure a system for looking at my level and knowing exactly how many blocks stacked I need...NEVER have I got it right the first try...usually by the 3rd....*ARGH*
Use these bubble levels:
RV Levels, Set of 2 - RV Designer E401 - Levels - Camping World
One Lynx leveler block is 1.25 divisions on the scale. Two blocks, 2.5, etc. we marked the scale on the lateral level with white nail polish. Works first try every time. If the ground is uneven, you may have to back up and stack the blocks where the tires were sitting when you checked the kevel.
Cheers,
Charlie
aircampr is offline   Reply With Quote
Old 11-28-2014, 02:19 PM   #44
aircampr's Avatar
Images: 21
Will Anderson levelers work to change a tire? The ones I saw were only 4" lift, and the AS manual says use 8" lift to change tire.
Is anyone using the Anderson levelers with a recent 23D? I can't find specs for axel spacing.
Charlie
Old 11-29-2014, 01:50 PM   #45
aircampr's Avatar
Images: 21
Correction...
Charlie
Manual says raise 6" to change a tire.
Old 03-15-2023, 07:08 PM   #46
Grosse Ile , Michigan
does anybody know of any of the original wheel chocks for sale?
Thanks in advance Brian
Micco is offline   Reply With Quote
Old 03-15-2023, 07:39 PM   #47
2023 23' International
springfield , Missouri
Wow, an 8 plus year resurrection!
xpcdoojk is offline   Reply With Quote
Who uses tandem wheel chocks? Splitrock Brakes & Brake Controllers 64 11-24-2021 07:12 AM
Fastway ONESTEP Wheel Chocks jcanavera Jacks, Stabilizers, Lifting and Leveling 5 10-03-2009 06:14 PM
Aluminum wheel chocks MW64OVERLANDER Jacks, Stabilizers, Lifting and Leveling 5 09-01-2008 09:58 PM
Wheel Chocks FordTruck Jacks, Stabilizers, Lifting and Leveling 42 04-18-2008 02:30 PM
Wheel Chocks pjtaia On The Road... 13 10-28-2005 02:27 PM
