Old 10-31-2014, 12:19 PM   #15
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
We have a set of aluminum wheel locks from Debra Kyle. You can contact her at parttimerunner1@aol.com. You'll need to known the narrowest point between your tires to get the right size. Love these things...
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 10-31-2014, 12:48 PM   #16
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Those are the ones I want.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 10-31-2014, 01:06 PM   #17
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
The reason I chose X-Chocks was the pressure they put on the tire surface is evenly distributed.
Doug and Cheryl
Old 10-31-2014, 01:13 PM   #18
1994 34' Limited
Ottawa , Ontario
We are big fans of Rotochocks. Have been using them for 15+ years. A little expensive but they last and work really well.
RonH is offline   Reply With Quote
Old 10-31-2014, 03:02 PM   #19
Winemaker
rgwatkin's Avatar
2012 28' Flying Cloud
Avila Beach , California
At the onset of my AS experience about two years ago I was using the scissor type locks on my 28ft AS. Interestingly while unhitching one day with the scissor lock in place the trailer rolled back slightly (maybe 2-3") and instead of the scissor locking the tires the scissor rotated whereas on one side the tire contact plate was higher then the other if you can visualize this. I was never able to get the scissor squared up after that and...it scared me as it could have rotated completely off the tires. I have a friend that has used scissors without issue but...one key difference is he has 17" tires where I have the stock 16" tires thereby providing a greater space between tires on mine causing a greater geometric stress. Since that experience, I have put 20k miles on our AS and only used standard chocks on the set of wheels not elevated for leveling purposed. I have never had a problem.
rgwatkin is offline   Reply With Quote
Old 10-31-2014, 03:22 PM   #20
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
Scary! Do you think the scissor chock may have been placed a little off centre, or perhaps not tightened enough?
I think the strongest point in favour of scissor chocks is that they will work on the side that's up on levelling blocks. A nice methodology (IMO) is scissor chock on the lifted side, and regular triangle blocks between the wheels on the other side.
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 10-31-2014, 03:24 PM   #21
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Originally Posted by SteveH View Post
I use a combination of these as conditions dictate:
Fastway ONEstep Tandem Axle Wheel Chock - Progress 84-00-4000 - Chocks & Levelers - Camping World
X-Chock Tire Locking Chock - BAL 28010 - Chocks & Levelers - Camping World
3604 - Camper Leveler
I really like the Andersen combination chocks/levelers as I frequently get into a site that is not level side to side, they eliminate the need for other chocks, and they can also be used as a ramp to lift the trailer in case of a need to change a tire.
We are so on the same page!
Andersens on one side:
Fastway on the other (this is just the unit, obviously)
Much more stable than I experienced with regular chocks.
SteveSueMac is online now   Reply With Quote
Old 10-31-2014, 03:29 PM   #22
TinTin's Avatar
Canmore , Alberta
Cool
White side out!! Nice!
Attachment 225448
Attachment 225449
Bob and Nancy
Old 10-31-2014, 03:32 PM   #23
dkottum's Avatar
I'm with you on the Fastway onestep chocks, but it seems to me a couple of boards are more compact and easier to use than the Andersen levelers?
Doug and Cheryl
Old 10-31-2014, 03:33 PM   #24
Winemaker
rgwatkin's Avatar
No..I do not think they were mis centered but...there are different kinds of scissors out there. Mine, although I do not remember the make, were hinged which probably contributed to the problem greatly.
Old 10-31-2014, 04:08 PM   #25
W , New England
You noticed! :-D
Old 10-31-2014, 04:10 PM   #26
W , New England
The Andersens are really quite ingenious! You get the EXACT amount of level you need without guessing and the added benefit is the pocket they create for the tires that reduces instability/rocking motion.
They definitely take up more room than boards but I absolutely love them!
Old 10-31-2014, 04:31 PM   #27
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I like the idea of the Andersen levelers but they didn't work on my 25' with 16" wheels. There wasn't enough room between the wheels to fit the leveler. I had to return them.
2012 Dodge Durango Hemi/AWD
Old 10-31-2014, 05:42 PM   #28
W , New England
Sorry to hear that. Mine's a 27 with the 15" Michelins and they've been great for that setup.
Who uses tandem wheel chocks? Splitrock Brakes & Brake Controllers 47 08-26-2014 09:20 PM
Fastway ONESTEP Wheel Chocks jcanavera Jacks, Stabilizers, Lifting and Leveling 5 10-03-2009 06:14 PM
Aluminum wheel chocks MW64OVERLANDER Jacks, Stabilizers, Lifting and Leveling 5 09-01-2008 09:58 PM
Wheel Chocks FordTruck Jacks, Stabilizers, Lifting and Leveling 42 04-18-2008 02:30 PM
Wheel Chocks pjtaia On The Road... 13 10-28-2005 02:27 PM
