Old 03-06-2007, 04:06 PM   #1
gparker's Avatar
1970 31' Sovereign
Denham Springs , Louisiana
What kind of jack do you use for flats, etc?
I need a jack to carry around with the trailer in case of a flat or something. What is the best thing to get? A bottle jack has a very small " Head" on it and looks like it would phch throught the floor if the jack slipped, and an automative floor jack takes up alot of room. Suggestions?
gparker is offline   Reply With Quote
Old 03-06-2007, 04:09 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
With a two axle trailer, use a ramp of 2 by 6 or 8 or the yellow leveling blocks. Run one wheel up on the ramp and the other is suspended in mid air.
Bill
Just my personal opinion
Old 03-06-2007, 04:42 PM   #3
ScottW's Avatar
Hernando , Mississippi
Bill is correct. However I bought a 'trailer jack' years ago for a large horse trailer. It is space age plastic (aluminum ones available at higher cost), with metal 'feet'. It is a ramp with a platform on top that conforms to the wheel. Either pull up on it, or back up on it, depending on which tire is flat. Works great. Any camper place will have them, or look on line.
Hope you don't need it!
Rgds,
Scott
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
ScottW is offline   Reply With Quote
Old 03-06-2007, 05:51 PM   #4
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
I use the leveling blocks while on the road and a Bottle jack with a 1/4" aluminum plate when around the house. Do not jack on the mounting plate that is between the wheels. It is too easy to slip off or bend the plate. Of course, do not jack on the axles.
Old 03-06-2007, 06:31 PM   #5
2005 16' International CCD
Ogden , Utah
My truck has a screw-type jack that is rated well over what my trailer weighs, and it works fine with my trailer, so I don't have to carry another one. I always have an assortment of yellow blocks and 2 X 6 boards along, so I position something under the 'jack here' label on the underside of the trailer for the jack to lift against ahd distribute the forces, and don't have any problems with the jack damagining the metal on the underside of the trailer.
My trailer is a single axle so I have no alternative - if I had a double axle I would use one of the methods others have mentioned above. Whatever method you decide on, it is good to practice at home so you know you have everything you need before having to try it for real, alongside a road somewhere!
RDM16CCD is offline   Reply With Quote
Old 03-06-2007, 06:40 PM   #6
SteSpot's Avatar
1968 28' Ambassador
1982 24' Airstream 240
Ventura , California
Smile Trailer Jack
Hello, I am wondering if a Good Sam Card Emergency Service card might work? pj
Paula & Ed
Suite Spot
WBCCI # 8252 Air#13593
1968 28'Ambassador
2011 GMC Yukon Denali
1982 24'Motorhome (82Ste P)
SteSpot is offline   Reply With Quote
Old 03-06-2007, 06:45 PM   #7
Airstreamin and luvin it
Devoman's Avatar
Northwest Panhandle , The Sunshine State/WBCCI 6637
Jack
Here is what I use if I ever get into trouble.
Trailer Aid
CHANGE IS GOOD.LIFE IS GREAT!
It just cant get any better than that.
Devoman is offline   Reply With Quote
Old 03-06-2007, 08:26 PM   #8
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Trailer Aid
Devoman,
While I usually use 2X6 or 2X8 treated lumber to pull up on, I have been looking at that Trailer Aid for awhile now. Last week I hefted it while at Camping World and it is definately heavier and sturdier that it looks in the picture. I see one in the near future.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 03-06-2007, 09:08 PM   #9
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
I use my leveling boards for campgrounds. Works good for dual axles. Nothing extra to carry.
Michelle TAC MT-0
Sarah, Snowball
Old 03-06-2007, 09:18 PM   #10
Round on both ends
SafeHarbor's Avatar
1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
I use an inexpensive "Rhino" car ramp that I got at AutoZone. I've had to use it and it makes a great impression on the locals who want to help. But adjust your mirrors so you can see it!
They come in pairs for about $50, and I've used two of them on the Argosy when I re-tired it, but didn't want to tow it the tire dealer.(Yes, they were that old and bad.)
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Old 03-06-2007, 11:16 PM   #11
wheel interested's Avatar
2007 23' International CCD
Lapeer , Michigan
We use a trailer-aid too like Devoman. You have to love having double wheels and being able to use this. We have never had to use it yet though.
Trailer Parts and Acc. trailer couplers
Caroljb
photography
wheel interested is offline   Reply With Quote
Old 03-08-2007, 12:35 AM   #12
gparker's Avatar
1970 31' Sovereign
I am thinking the trailer aid or the home-made version of one looks like the way to go. I going to work on my brakes tomorrow so I will try it out. Thanks to all...
Greg
Old 03-27-2007, 06:23 AM   #13
Wayward's Avatar
Cary , North Carolina
Here is another style of quick change jack that works very well. These will work on single axle trailers too. I've used it with square and round axles.
Cabela's -- Quick-Change Trailer Jack
...........Scott
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 03-27-2007, 06:42 AM   #14
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
only if you are sure the person responding knows how to drive a jack, and where to place it.
voltage for electric jack maznblu Jacks, Stabilizers, Lifting and Leveling 3 04-16-2004 08:32 PM
removing electric jack CHRIS CANNON Our Community 0 09-30-2002 06:51 PM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Jack Resync jcanavera 2001 Safari 1 07-03-2002 10:45 AM
Where do you suppose they put the antenna jack -'73 safari ? Chuck 1969 - 1973 Safari 14 06-13-2002 11:34 AM
