Old 04-16-2004, 07:35 PM   #1
Ann Arbor
voltage for electric jack
The electric tongue jack on my '77 Sovereign works only with 110v. Over the winter I had forgotten this and was frustrated when I plugged the umbilical in from the truck and couldn't get the jack to work.
Is there a way to wire the jack so that it works with either 12v or 110?
Thanks.
Eugenie
maznblu is offline   Reply With Quote
Old 04-16-2004, 08:06 PM   #2
LOST , Hawaii
Are you absolutely certain it is 120v? Does it have a regular 3 prong house plug on a cord?
John
74Argosy24MH is offline   Reply With Quote
Old 04-16-2004, 08:27 PM   #3
RichardT's Avatar
"Is there a way to wire the jack so that it works with either 12v or 110?"
actually it is only working on 12 volts, supplied thru the converter from 110v
you have a dead battery or are not wired correctly ,
no jack is 110v only 12 volts
RichardT is offline   Reply With Quote
Old 04-16-2004, 08:32 PM   #4
Wired correctly, it should work from either the tow vehicle, or the coach 12V system.
Navigator is offline   Reply With Quote
Electric/Manual Jack Security Question docbluedevil Jacks, Stabilizers, Lifting and Leveling 1 11-01-2003 11:50 PM
Moving the camper without the front jack wheel Silvertwinkie Our Community 9 07-22-2003 06:46 PM
Manual Jack Broken - Best Elec. Jack? montanaandy Jacks, Stabilizers, Lifting and Leveling 9 07-10-2003 06:33 AM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Jack Resync jcanavera 2001 Safari 1 07-03-2002 10:45 AM
