Old 04-26-2004, 07:30 PM   #1
flamingo-kid1's Avatar
1967 28' Ambassador
Rockford , Illinois
Send a message via ICQ to flamingo-kid1 Send a message via AIM to flamingo-kid1
Unhappy Vertical slits after jacking for new wheels
We had new wheels and tires installed today, and the technician at the tire store was very careful in jacking up the trailer, First he jacked up the right side and installed rims and wheels,and then jacked up the left side and did the same. When he lowered her, I noticed two vertical slits in the aluminum on the right side, one to the left and one to the right of the wheel well. Upon close inspection, there is one small slit on the left side of the trailer, (in the wheelwell) also. Can anybody shed any light on this odd problem? I had my camera with me, and took "before" and "after" pics, although I won't know if I actually captured the wheel well "before," since that wasn't what my lens was after. I have to get the film developed to see. The trailer WAS jacked up very carefully by the area on the axle beam, he put a jack on each wheel axle on each side (two jacks) so how did this happen???? Anybody heard of it before???
flamingo-kid1 is offline   Reply With Quote
Old 04-26-2004, 07:56 PM   #2
Sounds like your stringers popped through, if they're on your belly pan.
Usually happens when your body mounts are worn out and bouncing occurs.
Good luck with the repair. Cliff.
millionairstream is offline   Reply With Quote
Tires & Wheels for a '66 Overlander 66Overlander Tires 16 05-28-2004 11:20 PM
16" wheels for my A/S Chipster Our Community 2 03-18-2004 01:11 AM
Wheels for 1961 Overlander David Hall Wheels, Hubs & Bearings 19 01-29-2004 07:24 AM
alloy wheels T&R Wheels, Hubs & Bearings 3 05-19-2003 06:52 PM
