10-19-2015, 08:56 AM
2010 23' Flying Cloud
High point
, North Carolina
Using Andersen Levelers
We bought a 2010 23' flying cloud. 2 axels, tires about 4 - 5 " apart. We used the red 4" andersen levelers on our old trailer (keystone bullet) but the tires we about a foot apart. They're very convienent..you just put them under the tire and pull the trailer onthem to the level you need. It looks like i can put a leveler between the tires but its pretty snug. Does anyone use these levelers or would you recommend something else?
10-19-2015, 09:11 AM
Princeton
, New Jersey
If you are on a site that would require the use of 2 levelers you could cut an inch or 2 off the leading edge on the one that goes between the axles.
I have 16 inch wheels and LT225 tires on my trailer and can fit a stock leveler in there with a kick.
2004 Excursion 4x4
10-19-2015, 09:21 AM
2005 28' Safari S/O
Paradise
They should work snug but fine without cutting. If not, this guide from Anderson will show you how to cut if necessary. You can cut off up to 4 inches. http://www.andersenhitches.com/uploa...%20details.pdf
Steve
"THE OLDER I GET, THE BETTER I WAS"
10-19-2015, 09:40 AM
Biloxi
, Mississippi
I cut three inches off of one after it jammed up a couple of times. Fixed the problem.
MICHAEL
10-19-2015, 09:42 AM
Oswego
Mine are snug, but I haven't had to cut them yet.
-Rich-
10-19-2015, 10:19 AM
2015 25' FB Flying Cloud
Manassas
, Virginia
We have not had any issues with the Andersons yet nor have we had to trim them.
10-19-2015, 10:41 AM
1995 25' Excella
xxxxx
, xxxxxx
I use them with my 1995 Excella with no cutting and no problems.
10-19-2015, 11:36 AM
2015 23' Flying Cloud
Moses Lake
Do the Anderson levelers fit in the bumper storage compartment?
10-19-2015, 12:01 PM
Manassas
, Virginia
I am pretty sure they do fit but I keep ours in one of the side storage areas.
10-19-2015, 12:33 PM
Princeton
, New Jersey
Having had the floor fall out of the bumper storage without that kind of weight in it I would not suggest it unless you check the condition and number of rivets holding the floor in place.
I had a gallon of motor oil and my sewer hose in there.
2004 Excursion 4x4
10-19-2015, 12:37 PM
2008 25' Classic
Full Time
I you are solo how easy are these to use? Do you just put the tow vehicle in park then walk back to put the chock under each leveler?
My Lynx levelers take up a lot of space as I have two sets.
What about when you have to remove them. Seems you have to be careful not to run over the big end. You'd have to back up a bit to take the tire off the chock and could go off the big end. Hard to judge when solo how far to move. Worried about tire damage.
Kelvin
10-19-2015, 12:47 PM
Princeton
, New Jersey
I would not use Park because there is free play in the drive train and the rig will roll against that changing the level setting.
Use the Emergency Brake.
2004 Excursion 4x4
10-19-2015, 12:55 PM
Full Time Adventurer
2007 27' International CCD FB
Nomadic
, USA
They're easy to use solo, I've done it a few times now. I have one of those large levelers I can see in the rear view however. Once they are placed, just back up onto them.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
10-26-2015, 07:53 PM
2016 28' Flying Cloud
2009 30' Classic
2008 27' Safari FB SE
Sussex
, New Jersey
The video by Airstream nerds shows the addition of 3M 2" Outdoor Tape to the levelers I expect to improve traction when pulling onto the levelers. Has anyone found this a necessary add on or are they sufficient as delivered?
10-26-2015, 08:20 PM
2020 Classic 33
Box Elder
, South Dakota
90% of the time solo with the Andersens. Electronic LevelUp mounts to a small 3m Lock loop on the the bottom of the front window. Get full aligned, identify low side, position the Andersens, slowly pull forward until the LevelUp turns green. Set the parking brake (as mentioned just putting in park usually results in some roll).
Put the secondary blocks under the back side of the Andersens. I then use BAL X-chocks on both sides, lower the jack and start the unhitch process. Prior to releasing the ProPride locks I slip the truck into neutral, hold the brake and release the parking brake. Then into park. This is to release any tension in the ProPride and I finish unhitching.
Total time usually about 15 minutes solo start to end, whether hooking up or unhitching. Faster with the wife since she can position and remove the Andersens so I don't have to run back and forth.
Love them. Sitting on them in Scottsbluff NE as I write this.
Opps that didn't read correctly. The 'trailer' is sitting on them and I am on my couch....
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
10-27-2015, 04:51 AM
Biloxi
, Mississippi
I had them slip once. Suspect my fault for not putting in far enough.
MICHAEL
10-27-2015, 05:01 AM
2014 25' Flying Cloud
Cuddebackville
, New York
It was too tight on my 25' so I returned them. Even if I could get them to work they could jamb between the wheels when pulling off. This made me uneasy to try them solo- I'd want someone watching to prevent damage to something.
They were also pretty narrow and sank into the ground.
I like the idea of them but it just didn't work for me. YMMV.
2019 Ford Expedition Platinum
10-27-2015, 06:56 AM
2015 27' Flying Cloud
Newberg
, Oregon
Mine have slipped forward about a half inch or so every time I use them. I wonder what I'm doing wrong or how I can increase the friction between the chalk and the curved bit.
Mike
10-27-2015, 07:20 AM
Manassas
, Virginia
Tire slipping is why I decided to use the grip tape. I have only had the tires slip on the plastic not the plastic on the ground. Even if they slide a small bit on the ground I don't see a problem because once the AS is on them the weight keeps them from moving.
I can see Wayne&Sam's point regarding solo use - it takes a little patience and getting in and out a couple times but they fit fine between the tires on my 25' and I have not trimmed them. According to manufacturer you can cut a couple inches off of the ends if you think they are too long without screwing them up.
10-27-2015, 08:50 AM
Princeton
, New Jersey
I watched the Official Andersen youtube and saw no mention of tape applied to the leveler.
There is no need for "traction" between the tire and the leveler. Traction is a mean of defining the interaction between two surfaces that are moving against each other, ie tire to ground. There is no movement between the leveler and the tire or the leveler and the ground.
The only thing I can imagine might be if you are on soft ground the chock might have a tendency to fly out from under the leveler as it is pushed into the ground. Is that the surfaces they mention in the video?
2004 Excursion 4x4
