Old 11-22-2015, 04:04 PM   #29
wecoyote's Avatar
2014 30' Flying Cloud
Royal Oak , Michigan
Our Andersen Levelers arrived just as the snow began here in Michigan. I guess we are going to have to wait for either a thaw or next season!
I'm looking forward to not carrying the "lumberyard" of ramp sections I had built.
Royal Oak, MI
WBCCI #: 8356 (the same number my grandparents had from 1963 to 1981)
AIR #: 104322
Henry - 2013 F150 Super Crew XLT w/ HD Towing
wecoyote is offline   Reply With Quote
Old 11-29-2015, 06:50 AM   #30
wecoyote's Avatar
We had a nice enough weekend here in SE Michigan to go out. We are at the Algonac State Park camping in 25 degree weather!
With our 2014 Flying Cloud 30, the levelers work great! What used to take 10 minutes, now takes 1. We were leveled in no time.
Using the Andersen Levelers and the X-chocks, this is the fastest we have ever been able to level. Why didn't we get these sooner?!?!
Royal Oak, MI
AIR #: 104322
Old 11-29-2015, 06:19 PM   #31
We have really enjoyed our Anderson levelers. So far they are durable and have done the trick. The only slight issue I have had is when packing up to go, I have to back onto them a bit more to release the pressure on the chock. These levelers have made my leveling experience much better!
ras.robshort is offline   Reply With Quote
Old 11-29-2015, 06:34 PM   #32
Tincampers's Avatar
Sneedville , Tennessee
We've only used ours once and that was on a pea gravel pad so they sank some. But they were easy to use and we were level pretty quickly. My wife even picked them up fast.
Tincampers is offline   Reply With Quote
Old 11-29-2015, 08:11 PM   #33
silverlabs's Avatar
2015 28' Flying Cloud
2014 25' Flying Cloud
Waxahachie , Texas
I have used these for the last year and a half and never had them slip. Probably a total of 80 uses. Plenty of room on both my 25FC and 28FC. Just put 16" wheels and tires on the 28 and they are a little tighter between the tires, but they fit by basically jamming them in under the tire a little more. I love these as I can basically look at my level initially and I know by how far off I am, how much I need to pull onto the levelers. I pretty much hit it first time every time. Great accessory. I have had to use once with a couple of lynx blocks on ground as we were in a very uneven site. Still worked fine.
silverlabs is offline   Reply With Quote
Old 09-29-2016, 07:50 PM   #34
2014 23' FB Flying Cloud
Park City , Utah
Need 2 Anderson levelers for 2-axle trailer?
I'm purchasing a 2014 FC 23 FB, 14 inch tires. I have an anderson leveler that I used on my Bambi, but curious--do I need another for the double axle, using 2 of them, or is it OK to just use one under one tire and let the other wheel hang in the air.
Actually...just reading my own words I think I know the answer, but I'll send it anyway. If I need two, will I need to cut them down to fit?
pcskier is offline   Reply With Quote
Old 09-29-2016, 08:21 PM   #35
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Buy another. You might have to trim a bit off one. I would wait and see before doing the surgery.
MICHAEL
Old 09-30-2016, 09:39 AM   #36
AStreamNerds's Avatar
2015 25' FB Flying Cloud
Manassas , Virginia
We did not have to trim ours for our 25 FB
You Tube Channel "Airstream Nerds":
https://www.youtube.com/c/airstreamnerds
Find Us on Facebook: https://www.facebook.com/airstream.nerds.7
AStreamNerds is offline   Reply With Quote
Old 09-30-2016, 09:55 AM   #37
HowieE's Avatar
Princeton , New Jersey
Images: 12
The need to trim is a function of the ground you are parked on. Flat concrete or asphalt is not the place to check if trimming is necessary. If you are on soft ground or on grass they may lift the leveler just enough to make it hard or impossible to slip the leveler in place.
Trim one before you travel and be ready for the unexpected.
2004 Excursion 4x4
Old 01-04-2017, 12:54 AM   #38
2016 25' International
Deerfield , Massachusetts
Originally Posted by ghaynes755 View Post
90% of the time solo with the Andersens. Electronic LevelUp mounts to a small 3m Lock loop on the the bottom of the front window. Get full aligned, identify low side, position the Andersens, slowly pull forward until the LevelUp turns green. Set the parking brake (as mentioned just putting in park usually results in some roll).
What is this "Electronic LevelUp" magic that you speak of? I must have it!
thiel is offline   Reply With Quote
Old 01-04-2017, 07:30 AM   #39
2017 27' Flying Cloud
London , Ontario
Maybe something like this? I'm getting one for the upcoming season, but held off buying so far because I hate it when I buy something and a new one is released shortly after I buy it!
https://www.amazon.com/LevelMatePRO-.../dp/B01FGGSWPW
Philip Jones is offline   Reply With Quote
Old 01-04-2017, 10:25 AM   #40
jayseejay's Avatar
2015 27' FB Eddie Bauer
2011 25' FB Flying Cloud
Fernandina Beach , Florida
Here is the LevelMatePRO unit installed in the closet of our 27' EB. It connects by BT to your phone even while your driving, so you can evaluate the levelness of sites on the fly, as well as when you drive up on leveling blocks or rollers. It graphically indicates on your phone not only which way your AS is leaning, but by how many inches. All this can be accomplished with exterior physical levels, but I find this device little easier, particularly when traveling alone. Joe
Name:	ImageUploadedByAirstream Forums1483547079.081345.jpg
jayseejay is offline   Reply With Quote
Old 01-04-2017, 11:45 AM   #41
Wow...thanks to both of you!
Old 01-05-2017, 09:02 AM   #42
wecoyote's Avatar
Attachment 277638
How long have you had your LevelMatePRO? I have heard that the battery life can be an issue. We got one for Xmas this year and can't wait to install it!
Royal Oak, MI
AIR #: 104322
Andersen Levelers-Anyone tried them. interstateflyer Towing, Tow Vehicles & Hitches 27 04-27-2016 10:20 AM
Andersen levelers and a 25' gpt 2009-2015 Flying Cloud 22 06-12-2015 11:23 AM
Levelers and airbags CBBOB Mechanics Corner - Engines, Transmission & More... 2 09-01-2003 04:25 PM
Airbags and self-levelers fangthorpe Mechanics Corner - Engines, Transmission & More... 7 08-12-2003 11:16 AM
