Old 06-15-2006, 07:27 PM   #1
frozen chosen's Avatar
Trailer jacking question
Does it make any difference whether the trailer is hooked to the TV or not when jacking to change a tire or otherwise work on the wheel/axle?
frozen chosen is offline   Reply With Quote
Old 06-15-2006, 07:43 PM   #2
peegreen's Avatar
1998 31' Excella 1000
South Berwick , Maine
If you have a tandem axle, the easiest way to get one wheel off the ground is to pull one wheel on the trailer up on boards high enough to raise the front/rear wheel on the same side. In this case the TV would remain hooked up.
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Old 06-15-2006, 07:45 PM   #3
Images: 59
I would feel safer if the tv was hooked up and the parking brake was set.
This doesn't mean I wouldn't also chock the opposite wheels and use jackstands.
Old 06-15-2006, 07:48 PM   #4
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
If you are still hooked up you do not need to block the wheels on the trailer. Otherwise, block both forward and backwards on the other side before lifting. Remember: you can not jack under the axle if it is a torque type axle. Jack only at designated jacking spots.
Old 03-22-2007, 11:12 PM   #5
jump's Avatar
2013 30' International
lubbock , Texas
how does one find those designated spots if they are not clearly marked on the trailer???????
jump is offline   Reply With Quote
Old 03-22-2007, 11:31 PM   #6
jump's Avatar
lubbock , Texas
never mind my question...i found a good thread on this by tinsel loaf ... jacking an airstream ... i usually dont read the instructions until after i have already asked my stupid question.
Old 03-28-2007, 09:48 AM   #7
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
That's OK, sometimes reading the instructions only gets in the way of really getting something done.
>>>>>>>>>>>>Action
Skylight part question ColtSAA45 Roof Vents, Skylights & Fans 3 04-22-2004 08:05 PM
Dumb question - 345LE - does the gennie charge the auto battery? williamhenshall General Motorhome Topics 6 08-26-2002 05:49 AM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Tire sizing question casarodante Tires 5 07-02-2002 10:19 PM
