Old 10-25-2008, 07:24 PM   #1
jkrauk's Avatar
1978 23' Safari
1956 22' Flying Cloud
Orlando , Florida
Tongue Jack wire on '70s AS ?
Trying to finish up my 78' AS Safari project and getting to the tung jack. Could anyone look and see how their wires are up front on the trailer? I have one wire coming down for the tung jack (going nowhere), then two wires off the kill switch, then two wires coming out of the frame, one connected to the kill switch, the other I assume connects to the other kill switch wire. Where does the tung jack connect? Is there a wire missing that goes to the battery? Or does one of the two wires coming out of the frame serve double duty?
Any help would be appreciated.
Thanks, John.
jkrauk is offline   Reply With Quote
Old 10-25-2008, 08:25 PM   #2
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
You should have three wires coming from inside the shell.
1. 12V for the tongue jack -- this power comes through a thermal circuit breaker, which resets after 20-30 seconds.
2. 12V from the battery to the breakaway switch.
3. Wire going back from the breakaway switch to the brakes.
Zep
Old 10-25-2008, 08:41 PM   #3
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
I have a new jack. The one wire goes to the battery/charge wire. The breakaway is also on the same connection. The ground is the mount to the tongue.
Neil.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 10-25-2008, 08:50 PM   #4
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
My jack wire I believe was Orange. The PO took the electric jack off cause He thought it Bad. I found a bad Breaker. CONSULT your service manual or maybe someone has one they can tell ya what color.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Unknown pink w/green stripe wire at tongue Skater Electrical - Systems, Generators, Batteries & Solar 1 08-08-2014 08:31 PM
Green wire/White wire magnets robbier49 Brakes & Brake Controllers 3 07-08-2009 06:26 PM
Two wire and three wire converters??? max7 Batteries, Univolts, Converters & Inverters 1 02-28-2008 05:27 PM
Tongue weight verses tongue height - level the WD hitch? HowieE Hitches, Couplers & Balls 12 11-17-2007 01:02 PM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 11:09 AM
