Old 12-08-2005, 12:28 AM   #1
1992 34' Limited
Falls Church , Virginia
Tongue Jack - Which one?!?
Hi all -
Looking to add an electric Tongue Jack to SilverToy as the PO? removed the one that was there. SilverToy is a big girl - '92 34' Classic Limited.
So now the questions -
Who has which Brand / Model??
Why that one (Sale, recommended, came with it,etc...)?
Would you get it again if it blew tomorrow?
If so, why? If not, why not?
Any issues I need to especially consider ( wiring, ease of manual use, reliability, etc...)?
Fire away out there - looking forward to all the good info!
Thanks.
Axel
SilverToy is offline   Reply With Quote
Old 12-08-2005, 07:36 AM   #2
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Originally Posted by SilverToy
Hi all -
Thanks.
Axel
A good question since I've owned 3 trailers in my life that had an electric jack. The only thing that was special about the jacks that were supplied on my two Airstreams has been a built in light that can illuminate the hitch area.
Quite honestly the thing I liked best about the jack on my SOB was that if it it failed, all I had to do was pop open a cap on top and insert a crank handle. On the Airstream you have to remove the jack head and crank from there. Then you must resynchronize the jack prior to replacing the head on the jack. If you fail to do this you end up screwing up the gears in the jack.
Personally if I had to replace my jack I would look for a model that had the proper weight rating, maybe having a light feature, and hopefully a model that wouldn't require removing the head, if you had to go to manual mode.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 12-08-2005, 08:14 AM   #3
cosmotini's Avatar
1963 24' Tradewind
Highland , Illinois
Images: 83
Our International CCD has a Barker jack. It has a bubble level built into a cap on top of the jack that you remove.
You insert the manual crank tool and crank from there.
Dennis
cosmotini is offline   Reply With Quote
Old 12-08-2005, 08:33 AM   #4
Axel, the H&H Superjack from Barker mfg works well for us, and their parts and after-sales service has been excellent. This link gives a photo and details: http://www.rvstuffusa.com/hhsuperjackbybarker.html
Nick
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 12-08-2005, 08:34 AM   #5
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Dennis
Mine had the same jack..The emergency jacking feature was convenient, but the bubble level was a total waste of time. Unless the site was perfectly level, there was enough flexibility in the jack shaft that the jack would flex ever so slightly, but enough that the level was useless.
I found that the heavy-duty jack from Camping World is plenty sufficient for any Airstream and the bolt patterns are pretty standard.
John W. Irwin
WBCCI #9632
Old 12-08-2005, 09:12 AM   #6
1992 34' Limited
CW Jack Question
Pahaska et al -
Thanks for the replies so far. Hoping for a bit broader spectrum, but who knows....?
Does the CW jack have a easy access for manual jacking? Not so worried about the lights and SilverToy has plenty of lighting near the jack area, level too.
Also, is the price of $199 reasonable or could I do better (with $1 shipping as an added bonus). All you internet shopping gurus out there?
Axel
Old 12-13-2005, 10:51 PM   #7
1992 34' Limited
Dust Bin of Forums....
Hi all -
Is it because the temps are low - is that why the Toungue Jack question lingers in the dust bin of forum replies....?
Common folks - help me out with a Spring Project. Need input to decide on the 'right' unit to get....
Curious for input!!!
Axel
voltage for electric jack maznblu Jacks, Stabilizers, Lifting and Leveling 3 04-16-2004 08:32 PM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Electr. Tongue Jack Wiring?? roessler Jacks, Stabilizers, Lifting and Leveling 12 07-17-2002 11:00 AM
Jack Resync jcanavera 2001 Safari 1 07-03-2002 10:45 AM
New tongue layout FrankR Cleaning, Stripping & Polishing 0 03-07-2002 08:51 PM
