Old 08-04-2011, 11:20 AM   #1
star kitty's Avatar
1967 20' Globetrotter
denver , Colorado
Tongue Jack Replacement - '67
Hello.
My tongue jack on my 67' Globetrotter failed recently. It landed right onto the ball - what luck!
Anyway, I have been to two specialty trailer stores locally and there are similar replacement products, but they are just not quite right. The outer tubing that houses the jack is just a little too wide and I don't think it will fit into the existing hole on the tongue. It's about an 1/8" difference.
Has anyone replaced their tongue jack and if so, where did you get your new part? I have called Inland RV (waiting for return call as they are checking on it) and Out of Doors Mart and my local Airstream dealer and have been unable to locate a replacement part.
Picture of old jack included.
Thank you.
star kitty is offline   Reply With Quote
Old 08-04-2011, 01:38 PM   #2
Originally Posted by star kitty View Post
Hello.
Thank you.
What is the diameter of the jack "hole" that's in the coupler?
Old 08-04-2011, 03:40 PM   #3
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
On my 67 I enlarged the hole slightly to fit the newer jacks and then put the old crank handle on so it still looks original.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 08-04-2011, 04:20 PM   #4
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
On my 65 Safari I installed an Atwood elect. jack. It is the lightest model and fit perfectly. I believe it is 2" diameter. It was on sale and only cost $180. I put a battery box behind the propane tanks.
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 08-04-2011, 04:31 PM   #5
star kitty's Avatar
denver , Colorado
I did get a return phone call from Lisa regarding the part. Thank you.
At work today but can check that tomorrow.
Shackman - how did you enlarge the post hole on the tongue?
Old 08-04-2011, 04:32 PM   #6
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Air powered die grinder.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Interesting Tongue Jack electrical problem Wingeezer Jacks, Stabilizers, Lifting and Leveling 15 10-12-2012 10:08 PM
OK to use a jack instead of blocks to level? KYAirstream Jacks, Stabilizers, Lifting and Leveling 27 09-18-2012 06:42 AM
Jack & Lug nut wrench Tim_S Tires 41 10-31-2011 08:27 AM
Ultra Fab Odyssey 3000 Tongue Jack indy Jacks, Stabilizers, Lifting and Leveling 0 04-15-2011 09:49 AM
Need Tongue Jack - Suggestions? kj78133 Jacks, Stabilizers, Lifting and Leveling 16 02-23-2011 05:55 PM
