Old 09-22-2005, 03:43 PM   #1
1978 25' Tradewind
Roseland , Florida
Tongue jack replacement?
Hi all,
After dealing with an intermittent electric tongue jack for awhile it has finally bit the dust. Luckily it had one more nudgein it and I got it off the vehicle, but it is stuck in the extended positionl The motor is shot. I would prefer to just replace this with a simple hand crank version. Sometimes lower tech is better. Has anyone out there done this switchover? Is it an airstream specific deal, or is the bolt pattern universal?
Eric, Tina and Kierstin Hedin
'78 Tradewind - Homeschooling RV Tech
kooblekidz is offline   Reply With Quote
Old 09-22-2005, 03:50 PM   #2
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Do you really
The bolt pattern is universal, but do you really want to revert to a manual crank jack? That was the first thing I changed on my last trailer that came with a manual jack. It's no fun cranking away under the Texas sun, in rain, or just cranking away in general.
John W. Irwin
WBCCI #9632
Pahaska is online now   Reply With Quote
Old 09-22-2005, 03:51 PM   #3
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Bolt patterns should be universal. I haven't had a hand crank jack in 10 years.....I don't miss it at all.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 09-22-2005, 05:35 PM   #4
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
Just buy a new power jack. Manual jacks strip just as quickly or perhaps even more frequently than the motors die. Crankin' on a 600lb or better tongue weight isn't any fun! Your back and arms will appreciate you.
Roger
Old 09-22-2005, 05:53 PM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I have a power tongue jack earmarked for our Overlander, if I didn't think it was worth it, I certainly wouldn't replace a perfectly good manual one. If you go new, they are about $200-300, depending on where you shop, and what you wind up with.
Old 09-23-2005, 11:47 AM   #6
1978 25' Tradewind
Roseland , Florida
tongue jack intermittent
OK, so after taking it apart yesterday and testing the switch in all kinds of ways I gave up and decided that the motor was shot. Today I'm out there and on a whim I hit the switch and voila! down goes the jack and then up goes the jack, now it works??!! What gives?
Old 09-23-2005, 12:04 PM   #7
85MH325's Avatar
Tipton , Iowa
Images: 37
It likes you! No other explanation!
Seriously, could have been a piece of gunk in the motor brushes, a corroded switch contact that finally made contact... the overheat switch (or internal circuit breaker...I think they have one???) finally made contact... a temporary short in the wiring and when it got moved the right direction, made contact... intermittent bad ground...
Who knows?!!!!
Roger
Old 09-23-2005, 03:09 PM   #8
sander17's Avatar
1996 28' Excella
Okemos , Michigan
Images: 42
kooblekidz, Same thing happened to me with a "superjack". If you would whack it with a screwdriver, the motor would decide to work again. It was an intermittent open in the motor windings. After a while, I just gave up and I use the manual handle on the top of the shaft. It has a lot of mechanical advantage, so it is a lot of easy turns. Beats $400 for a new one.
Dave
Okemos, MI
T.V.:'05 Dodge Ram 2500 4x4 Quad Cab Cummins
AIR#2276
sander17 is offline   Reply With Quote
Old 09-23-2005, 05:23 PM   #9
1978 25' Tradewind
Roseland , Florida
I hate magic when it comes to electric components! I may add one of those side bolt on trailer wheels to my a frame so that if the thing goes south when I'm not in a troubleshooting mood I can still get going.
Old 09-25-2005, 09:21 AM   #10
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Yeah, we did the same with ours. Two days before our maiden voyage (years ago), I decided to hitch up to see the fit, and the old electric bit the dust. Went to the local RV store to ask about a rebuild kit, where the guy just rolled his eyes and told me to get out a deep pocketbook. Soooo, I asked about the manual: It was 30-some bucks (back then).
As long as you keep the manual (or the electric, I guess) greased, it works well and easily, at least with our lighter rig. I've certainly seen lots of rigs here with poorly-greased or ungreased hand or electric cranks, and they are a real chore, either on the camper or on the little motor.
Lynn
WBCCI 21043
eubank is online now   Reply With Quote
Old 09-25-2005, 06:07 PM   #11
Nye Thatcher's Avatar
The electric jack manufacturer who supplied Airstream a couple of years ago had an exchange electric jack program. Check it out you might save A buck. Hope this helps.
Good Luck.
Nye
Nye Thatcher is offline   Reply With Quote
Old 09-25-2005, 07:27 PM   #12
Round on both ends
SafeHarbor's Avatar
1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
Um... Do you guys mean that you're NOT supposed to whack on the motor casing when the jack stops? That's news to me. I think mine actually has some marks from the handle for the equalizer brackets, but I've found it sufficient to use the base of my palm to get it running again.
Lubrication? (I thought it ran on magic.)
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
voltage for electric jack maznblu Jacks, Stabilizers, Lifting and Leveling 3 04-16-2004 08:32 PM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Electr. Tongue Jack Wiring?? roessler Jacks, Stabilizers, Lifting and Leveling 12 07-17-2002 11:00 AM
Jack Resync jcanavera 2001 Safari 1 07-03-2002 10:45 AM
New tongue layout FrankR Cleaning, Stripping & Polishing 0 03-07-2002 08:51 PM
