Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Jacks, Stabilizers, Lifting and Leveling
Old 03-20-2003, 07:36 PM   #1
dinoburb's Avatar
Profile:  1982 34' Limited
Tidewater , Virginia
Tongue Jack Repair
Well the electric tongue jack on my 31', 1978 Sovereign has developed a case of the randomly intermittent switch. I would like to replace the switch and I need to know the type of switch I need. I believe a DPDT momentary contact type is correct, but any advice would be appreciated. The bottom of the switch has 6 wire posts and what looks like a diagonal buss across the pins (?). I can't read the amp capacity of the switch so any help here, too, would be appreciated.
Sean
Old trucks and old trailers . . . a comfortable combination!
AIR 1446
W5CDR
A-6E All Weather Attack Driver, BUFF
USN Aircraft Maintenance Officer, Ret.
'91 Suburban R-2500 w/BBC
'78 Honda GL-1000
'72 Triumph T-100R Daytona
dinoburb is offline   Reply With Quote
Old 03-20-2003, 09:38 PM   #2
Still Working
smily's Avatar
Profile:  North Charleston , South Carolina
head twist
While we are on the subject........
Anyone ever rotated the head of their power jack so it will not be in the way of the flag poles?
I have the three pole holder and I cannot put a flag in the middle because the head of my jack is in the way.
I would like to move the switch and the head 90 degrees.
Smily
smily is offline   Reply With Quote
Old 03-21-2003, 07:25 AM   #3
fdx753's Avatar
Profile:  2003 25' Classic
Memphis , Tennessee
head twist
Ken,
I had the same problem. There is no way to rotate the head because of allignment of the three hole attachment. I attached my holder to the back of the LP tanks cover. I used garden hose washers against the alluminum cover and a 1/4" bolt with flat washers and a lock washer at the nut end. It seems to be working just fine.
Brian
WBCCI #5167
2004 Land Yacht XL396
2005 GMC Sierra
fdx753 is offline   Reply With Quote
Old 03-21-2003, 04:20 PM   #4
Still Working
smily's Avatar
Not so fast........
I have heard of people removing the "head" of the jack, (the motor) and rotating it 90 degrees on the shaft.
I am almost certain that one can do this. I was looking for someone who had done it.
Thanks for the input anyway,
Smily
Old 03-25-2003, 12:41 PM   #5
Profile:
Who makes this jack?
One of the gears in it wore out and I need a replacement. But I understand it is not an A/S-specific part. Maybe a generic-RV dealer can help me.
I already tried InlandRV and they said they would get back to me if they have it.
Justice - When you get what you deserve. Mercy - When you don't get what you deserve
Grace - When you get what you don't deserve
ipso_facto is offline   Reply With Quote
Old 03-25-2003, 01:53 PM   #6
Rickk48's Avatar
Profile:
When I bought my Bambi I had an electric added. At the time, as I recall, there were 3 manufacturers that I could choose from. I don't recall the actual manufacturer of the one I have, but the point is, these electric jacks are not specific or unique to Airstream, and at least three companies make them.
Rick Klein
'01 Bambi
'99 Land Rover Disco
Rickk48 is offline   Reply With Quote
Old 03-26-2003, 09:12 PM   #7
dinoburb's Avatar
Jack repair . . . I think my question was missed completely!!
My original question still stands. Any help wqith the switch??
Sean
AIR 1446
W5CDR
'78 Honda GL-1000
Old 03-27-2003, 06:15 AM   #8
Still Working
smily's Avatar
Answers to questions
The question was answered in the same post as the question. It is a momentary contact toggle switch. You can buy these at most any electrical supply house.
There is nothing exxclusive about this switch. I believe that several manufacturers make this switch including LEVITON who manufacturer most of the toggle switches in the electrical industry.
A distributor would be Graybar Electrical Supply. You can find them on the web or most any large metropolis.
I hope your question has been answered.
Smily
Disabling Tongue Jack Cracker Jacks, Stabilizers, Lifting and Leveling 10 11-14-2003 12:32 PM
Electric tongue jack not extending ipso_facto Jacks, Stabilizers, Lifting and Leveling 5 03-25-2003 12:58 PM
Electr. Tongue Jack Wiring?? roessler Jacks, Stabilizers, Lifting and Leveling 12 07-17-2002 12:00 PM
Jack Resync jcanavera 2001 Safari 1 07-03-2002 11:45 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vBulletin Plugins by Drive Thru Online, Inc.
