09-11-2016, 05:26 PM
Oxford
, Michigan
Tongue jack removal from 74 overlander
Hello,
I thought it is easy but I guess it is not. I am trying to remove the power tongue jack. I removed the screws and tried to pull the jack through the hole. It looks like there is a ring folded around the tube preventing the jack to get pulled out. Does anybody know how to get the jack out before I start taking the whole thing apart.
09-11-2016, 05:40 PM
1979 23' Safari
Wayland
, New York
Picture?
09-12-2016, 07:39 PM
Oxford
, Michigan
My trailer is out to get some welding done. As soon as I have it back I will send some pictures
09-12-2016, 09:24 PM
1979 23' Safari
Wayland
, New York
You are right though, should be 3 bolts and lift off. There are so many different jacks out there though it's hard to tell.
I wonder if there were 2 halves on this model, with the bottom tube bolting up to the bottom of the A frame the bolts holding the two halves together.
09-13-2016, 11:18 AM
1998 34' Limited
Lawrenceville
, Georgia
Rust maybe. May need a big hammer. If it isn't rusty underneath, add a photo. Never saw one that wouldn't come out after removing 3 bolts.
09-13-2016, 02:28 PM
1976 31' Sovereign
Oswego
AS used smaller dia. jack than is av. now. There is a ring in bottom hole. It takes a little effort to remove jack, this ring is not needed for larger dia. jacks. Top hole, no filler ring hole is same as bottom with ring removed, even tho hole is bigger bolts hold jack centered. You will probably ruin old jack removing.
09-14-2016, 05:59 PM
1975 31' Sovereign
West Liberty
, Kentucky
If the tube is deformed you may have to saw the lower portion off. This happened on my 1975 AS as a result of not retracting the jack one time. Expensive lwsson learned!!!
07-07-2020, 07:11 AM
Raleigh
, North Carolina
Hi,
I am having the same problem with my jack now. There is a ring or sleeve on jack that is a larger diameter than hole in a-frame preventing jack from being removed. Did you find a way to remove the jack?
07-07-2020, 08:40 AM
1976 Argosy 28
Buford
, Georgia
Originally Posted by Jparsley
Hi,
I just went through this on my 76 and since I was replacing the jack (old one was junk) I cut off the small ring that was stopping me (using an angle grinder). If it's like mine (old Reese) I think the ring was pressed on there and after all these years it was stuck - as I said I didn't care and just cut it off..
John
