Old 02-24-2015, 06:03 PM   #1
2011 30' Flying Cloud
Greenback , Tennessee
Tongue jack problem
I have a 2011 Flying Cloud 30 with a front jack problem. Recently the power jack on the tongue has malfunctioned. When I push the toggle switch up to raise the trailer, it doesn't work sometimes. No problem when the toggle is pushed down to lower the trailer. The motor doesn't labor, it just seems dead. At other times it may work fine for a while, then, if I stop for a moment, it won't work and I am forced to crank it by hand. Any ideas out the as to what the problem is? Someone has suggested a grounding problem, but it seems like it would not work in either direction if that were the case. My guess is a bad toggle switch, but I don't know how to test it.
Gneiss Guy is offline   Reply With Quote
Old 02-24-2015, 06:40 PM   #2
My Grandparents Airstream
Andrew Selking's Avatar
2007 28' Safari SE
Hillsboro , Texas
Send a message via AIM to Andrew Selking
Go buy a new toggle switch. I have had to replace mine twice. A new switch fixed it both times. It is hard to find a switch anymore that is made in the United States.
Andrew Selking
WBCCI #6062
International 3rd Vice President
"Airstream the Best trailer ever built."
Andrew Selking is offline   Reply With Quote
Old 02-24-2015, 07:14 PM   #3
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
Barker Part no 736-0009. Actuator Toggle switch. My Airstream Dealer had the switch in stock.
I had the same issue that you had. The jack was stuck but I was trying to disconnect the Airstream from my Jeep so I found my emergency crank and gave the jack motor a little turn. Then I operated the toggle switch with the crank still attached to the top of the motor. The motor sprang to life and whipped the crank across my arm, lacerating the flesh and exposing a great big vein on the underside of my forearm. Oops.
I assume that since the dealer had the part in stock, that this is not an unusual problem. Perhaps Barker may improve future switches. Perhaps I will not be so careless should the problem happen with my new switch. Good luck. Safety 24/7. Jim
Jim Flower is offline   Reply With Quote
Old 02-24-2015, 08:12 PM   #4
IanPoulin's Avatar
2011 28' International
Aldie , Virginia
Thanks for the post - I had asked the same question last year to no responses at the time. I'll check out the part for replacement try!
Ian
2011 Airstream International Serenity 28' - 30a/taupe
2013 Ford F150 v6-ecoboost with max tow and HD payload packages
2016 Ford F250 Crew 4x4 KR Diesel
IanPoulin is offline   Reply With Quote
Tongue jack problem Dbraw General Repair Forum 6 05-04-2014 05:34 PM
Tongue Jack Problem El Gitano Jacks, Stabilizers, Lifting and Leveling 5 09-29-2013 05:35 PM
Tongue jack problem Shads Shack Jacks, Stabilizers, Lifting and Leveling 1 05-02-2013 03:02 PM
Interesting Tongue Jack electrical problem Wingeezer Jacks, Stabilizers, Lifting and Leveling 15 10-12-2012 10:08 PM
Tongue weight verses tongue height - level the WD hitch? HowieE Hitches, Couplers & Balls 12 11-17-2007 01:02 PM
