Old 09-26-2013, 04:40 PM   #1
El Gitano's Avatar
Salem , Oregon
Tongue Jack Problem
I've got a 2007 19' international Bambi and the tongue jack just quit working. I've tested for voltage at the fuse and that's fine. Changed the fuse just to be sure. I took the top of the jack off and I can't tell what's going on in there. The light is not working either so I'm thinking power. Any ideas?
* 2007 International Custom David Winick #16 *
El Gitano is offline   Reply With Quote
Old 09-27-2013, 05:45 AM   #2
Gainesville , Florida
Check the connection to the battery. Jim
Old 09-27-2013, 06:15 AM   #3
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up If you have the LPG tank cover.....
.....check where the wiring runs under it, common cause for short there.
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 09-27-2013, 07:25 AM   #4
steverino's Avatar
2018 30' Classic
Ivins , Utah
The jack also counts on ground return through the body of the jack and the trailer frame. Paint on the tongue can interrupt the path. My unit had a lock washer between the flange and the tongue to pierce the paint, but stopped working once. Tightening the jack mounting bolts fixed the problem.
One test you can do is to take the head of the jack off, turn the light on, and touch an extra piece of wire from clean metal inside the jack to battery negative terminal. If the light comes on, you've got an open ground.
steverino is offline   Reply With Quote
Old 09-28-2013, 07:10 AM   #5
El Gitano's Avatar
Salem , Oregon
Thanks for the replays. I'll check it out in the next day or so and let everyone know what I find.
Old 09-29-2013, 05:35 PM   #6
El Gitano's Avatar
Salem , Oregon
It's working again
I took off the jack and it did have some rust and flaky paint. I cleaned up both the a-frame and jack then put it back together... and it still didn't work. I turned the light switch on and twisted the fuse holder back and forth and the light would flicker on and off. It turns out the wires going into the fuse holder had been pulled out enough the fuse didn't have a good solid connection.
Thank you all for responding so quickly.
