Old 03-09-2015, 07:12 PM   #1
2007 28' International CCD
Deland , Florida
Tongue jack maintenance
Seems like my electric jack works awful hard when lifting. It hasn't ever tripped the fuse but doesn't sound right to me.
Is there any maintenance I can do? I'm sure it should be lubed up. I see there is a plug on the tube where I could get to the screw. Should I pump grease in there?
I have a 2007 28'. Not sure of the make of the jack. It's original to the trailer.
Does a manual crank handle come with the trailer normally? I don't have one and that makes me nervous.
Thanks for any help.
printman is offline   Reply With Quote
Old 03-09-2015, 07:56 PM   #2
1974 Argosy 20
Kooskia , Idaho
I have never seen one where the jack tube could be lubed in any way. The heads can but even there, be careful, as the grease can melt into runny liquid and get into the motor head very easily. The best jack I ever had was an old Reese, no longer made but quiet, powerful, fast and the motor was above the tube, not offset to the side with the shaft subject to water from above. I still have one on my '74 Argosy, working after 40 years.
I am afraid to say that I think you just use them until the fail, then replace. You probably should have a manual crank, although if the main tube is the problem, the crank may not work better than the motor does.
Gears can be replaced from the motor to the tube drive in most jacks, along with switches, but not much else that I know of. (depends on the specific jack of course).
Old 03-10-2015, 01:36 PM   #3
ewbradshaw's Avatar
2008 27' International FB
Sioux Falls , South Dakota
Misplaced my crank but a 7/16 socket on an 6 inch extension using a inch socket arm works great. Just don't do it when the switch is on.
ewbradshaw is offline   Reply With Quote
Old 03-10-2015, 03:59 PM   #4
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
The only maintence that I do is with the jack fully extended spray the extended tube with WD 40 and then wipe off. There is dirt in the air and my attempted is to remove as much as accumulates over time.
>>>>>>>>>>>>>>Action
Action is online now   Reply With Quote
Old 03-10-2015, 04:17 PM   #5
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Technically, according to my manual, the jack should get annual maintenance. Since I store inside I've never performed any. I also remember back on my new 2001 Safari I had a jack failure due to it randomly blowing fuses. I opened it up only to fail to properly synchronize the head when I put it back together. Bottom line I screwed up the jack. Thankfully my dealer went ahead and exchanged the jack at no charge because the blown fuse problems even though I had caused additional damage to the gears. He found a shorted wire inside the jack but allowed me to keep the replacement.
So if you pull it apart for any kind of maintenance be sure you carefully check if the jack requires a resync procedure before putting the head back on.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 03-10-2015, 05:45 PM   #6
2000 30' Excella
Toledo , Ohio
If it a Baker Jack they recommend lubing the gears in the head check their website for info
woodfox45 is offline   Reply With Quote
Stabilizer jack maintenance ostream Jacks, Stabilizers, Lifting and Leveling 16 11-11-2010 07:32 AM
Bottle Jack Maintenance JBinKC Mechanics Corner - Engines, Transmission & More... 0 04-10-2010 07:57 PM
Tongue weight verses tongue height - level the WD hitch? HowieE Hitches, Couplers & Balls 12 11-17-2007 01:02 PM
Tongue Jack Repair dinoburb Jacks, Stabilizers, Lifting and Leveling 7 03-27-2003 05:15 AM
Electr. Tongue Jack Wiring?? roessler Jacks, Stabilizers, Lifting and Leveling 12 07-17-2002 11:00 AM
