Old 05-09-2019, 02:23 PM   #1
Ely , Minnesota
Tongue Jack issue
My jack will lower the trailer but it will not raise it. I took off the cover, disconnected the switch, ordered a new switch, installed the new switch....and the same problem exists. Any suggestions, beside getting a Husky?
bertheep is offline   Reply With Quote
Old 05-09-2019, 05:05 PM   #2
Mollysdad's Avatar
Mine did the opposite, it went up but not down, leaving me with the coupler hitched and the truck rear in the air and no way to unhook!
Since yours goes down, you have power.
Assuming you're not stranded, try getting the weight off the jack. Use a bottle jack or in a pinch, the tow vehicle's jack. Once the weight is off does it move? Mine did, but I didn't trust it. I think mine got in a position where the shaft was torqued against the sleeve and it didn't move. Why it went up but not down is still a mystery. Using the hand crank didn't work. Same problem.
Old 05-10-2019, 06:01 AM   #3
KK4YZ's Avatar
2017 23' Flying Cloud
Hiawassee , Georgia
Are you connected to shore power or using batteries alone? If the latter, whatís the state of charge on the batteries?
I donít recall seeing the type of Jack you have, but if itís one that uses limit switches, a bad limit switch is another possibility. The Atwood jacks supplied these days donít use limit switches, however.
KK4YZ is offline   Reply With Quote
Interesting tongue jack issue. AWCHIEF Jacks, Stabilizers, Lifting and Leveling 13 07-08-2017 06:04 PM
OEM Super Jack Parts (aka Tongue Jack) Michael_Wild Jacks, Stabilizers, Lifting and Leveling 18 12-19-2016 02:47 PM
Electric Tongue Jack issue gmoney Jacks, Stabilizers, Lifting and Leveling 4 08-28-2010 07:50 PM
