Old 01-26-2009, 11:48 PM   #1
2005 19' Safari
GLENDALE , AZ
Tongue jack for my Bambi
This is an old thread, but hopefully one of you guys will respond.
I am looking at adding the Atwood 80515 Deluxe 2500# power jack to our 19-foot Bambi. However, I am unsure whether this is the right jack for this trailer.
Atwood also makes a "short" model (the 80515 is the "standard"). Is the 80515 the right jack for our trailer?
Old 01-27-2009, 05:11 AM   #2
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
A jack is a jack, if the mounting hole work and the capacity is correct you are good. Be sure and fuse the wiring correctly. I purchased a refurbished jack from ebay for $99.00 and it worked fine. The big thing is the orintation of the jack head to be sure it clears the tanks.
On the short vs long, I think I would go long unless you have a obstruction. If the jack is to short then you may have to place blocks under it in certain conditions. I have a 2005 Safari and this is what worked for me your mileage may vary so be sure to think it all out.
Good Luck
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 01-27-2009, 12:31 PM   #3
2005 19' Safari
GLENDALE , AZ
Thanks for the quick response. Just curious, the jack may affect the mileage?
Old 01-27-2009, 02:10 PM   #4
Jim Clark's Avatar
It's used metaphorically to mean Your experience might be different, and is now used loosely to say You might have a different opinion. Sometimes seen as YMMV.
Jim N5TJZ Air# 174
2011 F150 Ecoboost
Old 02-16-2009, 12:15 PM   #5
2005 19' Safari
GLENDALE , AZ
Follow-up (02/16/09):
I installed the Atwood jack this weekend, and it is about the easiest upgrade I have ever done on our 19-foot Bambi. The whole front end of our Airstream is made up of Atwood parts, so the new jack just dropped into the same mounting hole. All I had to do was install the new mounting bolts, crimp a ring terminal on the end of the power wire and attach it to the battery terminal.
Removing the old Atwood hand-crank jack and installing the new electric model only took about 15 minutes (not counting the search for the holy tools -- Do you guys have this problem, too? I used to think my two boys kept moving my tools, but now that they are both approaching 40, I have concluded that it's my wife! Oh well, maybe my Alzheimer's is acting up again...).
Anyway, it was an extrememly quick and easy upgrade, and one that will undoubtedly be appreciated by both my wife and myself as we get closer to retirement.
Tongue Jack woes Minnie's Mate Jacks, Stabilizers, Lifting and Leveling 15 02-10-2009 04:05 PM
Temperamental tongue jack kooblekidz Jacks, Stabilizers, Lifting and Leveling 10 03-02-2007 08:45 PM
Tongue Jack - Which one?!? SilverToy Jacks, Stabilizers, Lifting and Leveling 6 12-13-2005 10:51 PM
Tongue Jack Happycampers Jacks, Stabilizers, Lifting and Leveling 1 12-21-2004 11:01 AM
Disabling Tongue Jack Cracker Jacks, Stabilizers, Lifting and Leveling 10 11-14-2003 11:32 AM
