Old 04-19-2009, 03:59 AM   #1
1972 29' Ambassador
Morris , Indiana
Tongue Jack
We now have a hand crank jack on our 73 AS. Would like to put an electric one on. But, not sure where to get power to run the jack??
Dona is offline   Reply With Quote
Old 04-19-2009, 04:14 AM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
The power jack hooks into the same circuit as the breakaway switch. You should find the wiring inside the tongue frame. Make sure you put a fuse in the line.
Old 04-19-2009, 08:37 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
I would suggest taking the power directly from the battery positive post and installing a 20 amp fuse in the line. The brake away circuit for the brakes should be a clean circuit just to insure nothing can effect it since it is a major safety system.
Buy the heaviest jack available because you will be using it to jack both the trailer and the TV while hitching if you are using a WD hitch.
2004 Excursion 4x4
Old 04-19-2009, 09:23 AM   #4
Lumatic's Avatar
1993 34' Excella
Images: 16
Nothing wrong with Howie's proposal but it will involve running and fishing new wires. The Airstream service manual shows the power jack hooked into the same circuit as the breakaway switch. Airstream planned for this dual use with the size of wires for this circuit. This circuit also has it's own factory installed circuit breaker. I also cannot imagine a circumstance when the power jack and the breakaway switch would be needed at the same time which, to me, makes a separate dedicated circuit for the power jack unecessary. Just my opinion.
Old 04-19-2009, 10:28 AM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Every travel trailer I've seen has used the breakaway switch power wire to power the jack. In order to use both at once, you would have to be riding on the tongue when the trailer fell off the tow vehicle while driving. If I were in that position, I think operating the jack would be the least of my concerns.
Old 04-19-2009, 01:05 PM   #6
richinny's Avatar
2011 34' Classic
it sounds like something andy might have tested in the past.
Ricky
Old 04-20-2009, 06:31 AM   #7
1972 29' Ambassador
Morris , Indiana
Thanks to everyone!
Tongue jack for my Bambi Phoenix Jacks, Stabilizers, Lifting and Leveling 4 02-16-2009 12:15 PM
Electric Tongue Jack darryl97420 Jacks, Stabilizers, Lifting and Leveling 0 05-25-2006 08:57 PM
Tongue Jack - Which one?!? SilverToy Jacks, Stabilizers, Lifting and Leveling 6 12-13-2005 10:51 PM
Tongue Jack Happycampers Jacks, Stabilizers, Lifting and Leveling 1 12-21-2004 11:01 AM
Tongue Jack Repair dinoburb Jacks, Stabilizers, Lifting and Leveling 7 03-27-2003 05:15 AM
