Old 04-14-2013, 07:20 PM   #1
1975 31' Sovereign
Jefferson City , Tennessee
Tongue Jack
My husband and I are in need of some help. We purchased a 1975 Sovereign 31 ft Airstream. When we purchased the Airstream it had an electric jack and at time of purchased worked, shortly after we moved and the the jack would not work. Hubby and father-in-law tried to get the jack to work again, unfortunately we had to scrap it. There were no markings on the jack to give us information on what type of replacement we would need. We would like some help on how to figure out what size jack we would need. We would like a manual and the whole lb thing has us confused, we tried to get help from a local Camping World about jacks but they were not as help as we would have liked. We decided it was time to ask the experts that have first hand experience.
In summary: What size tongue jack (lb) would we need for our 31 ft Airstream with a gross vehicle weight of 7200 lb?
TheBreeze is offline   Reply With Quote
Old 04-14-2013, 08:42 PM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
The only one I have experience with is the Barker 3000lb unit. Excellent unit, VG customer service. Several different models available.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 04-14-2013, 09:46 PM   #3
1974 Argosy 20
Kooskia , Idaho
Barker, Bulldog, Atwood all make good jacks. Reese has recently re introduced a line of jacks, but I have not seen one yet. Their old ones were great, but long discontinued. There may be others I am unfamiliar with. You need one in the 3000# range. Try to stay with quality name brand jacks, there are some poorly made offshore units which will not hold up. Many from even a quality brand may be sourced offshore, but are built to better standards, and are good units. What I am saying is you no longer can judge a hitch jack quality by where it is made, but the reputation of the brand probably is still a good indicator.
BTW, I think the current factory hitch jack is made by Barker.
Old 04-14-2013, 10:15 PM   #4
Kyle401's Avatar
1969 27' Overlander
SW , Missouri
I find top-wind manual units offer the most reliable (albeit higher effort) and cost-effective product. I've got a Ram A-frame 2000 lb jack in mine and it works great. I think I paid ~$15 at the local farm supply store.
Kyle401 is offline   Reply With Quote
Old 04-15-2013, 07:12 PM   #5
1975 31' Sovereign
Thank you all for your input. We had thought about an Atwood orginally, but I will definitely look into the other brands you all have listed.
Old 04-16-2013, 04:09 PM   #6
WineStream's Avatar
2005 30' Safari
Pleasanton , California
Images: 24
I recently replaced my who-knows-how-old electric jack with a Barker 3000lb one. I went with Barker based on reviews nad discussions in other threads here on the forums. I am NOT disappointed! I found the best price at: https://www.adventurerv.net/
WineStream is offline   Reply With Quote
Old 04-16-2013, 07:36 PM   #7
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
ebay is your friend when it comes to tongue jacks. Rebuilt with a 1 year warranty $79.00 to $114.00 do a search. Stay away from the Chinese jacks. BTW you don't need the lights they put on them either.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 04-16-2013, 08:06 PM   #8
Maniacal Engineer
barts's Avatar
Menlo Park , California
I've found a sturdy 5000 lbs manual jack to be just the thing; the effort involved is minimal for both myself and webspinner. Manual jacks are a lot
more reliable in my estimation.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 04-17-2013, 06:19 PM   #9
Erik Olson's Avatar
1974 29' Ambassador
CONCORD , North Carolina
Images: 20
Send a message via Skype™ to Erik Olson
I've got a rather desperate situation with a tongue jack tonight. On my 1974 ambassador, trying to remove the tongue jack, I have discovered there is a another cylindrical sheath / flange made to the column underneath the three bolt pattern plate on the frame.
Does anyone know how this sheath is made to the main column on the electric jack?
I wrongly assumed that after pulling the three bolts that I would be able to pull old-time Jack straight up out of the trailer tongue.
Erik Olson
1974 Ambassador 29' Ohana
www.tradingpathmedia.com
Erik Olson is offline   Reply With Quote
Old 04-17-2013, 06:47 PM   #10
Jim Clark's Avatar
Pictures
Jim N5TJZ Air# 174
2011 F150 Ecoboost
Old 04-17-2013, 07:40 PM   #11
Erik Olson's Avatar
1974 29' Ambassador
Images: 20
It's dark out, so I can't attempt the picture now, but the sheath in question appears to be a spacer, not numbered, just above part 23 in the attached diagram. When installed to the trailer's a-frame, this flange acts as a spacer inside the hole of the plate located about 4-6" below the top one (that you actually make the three bolts to).
A friend suggested that we Sawz-All the main tube above this flange / sheath.
As you can see in the drawing, it is slightly flared at the top, seemingly to keep the assembly from being removed from the trailer a-frame / jack mounting plate area, as the hole that the entire jack goes through) is just to small to get the flared ?
Erik Olson
Old 04-17-2013, 08:14 PM   #12
1976 31' Sovereign
Oswego , Illinois
My suggestion is you are going to replace jack do as your friend says sawzall off
Old 04-17-2013, 08:21 PM   #13
Erik Olson's Avatar
1974 29' Ambassador
Images: 20
Was afraid of that. Ah well, it was intermittent anyway and the gear / motor housing was actually chipped where the recessed bolts made it to the main column. A new Barker 3000 will be taking the original's place.
Erik Olson
Old 04-17-2013, 08:24 PM   #14
Jim Clark's Avatar
Are you sure it not just pressed on and can't be broken loose with a chisel ? Drawing better than a picture anyway.
Jim N5TJZ Air# 174
2011 F150 Ecoboost
