07-10-2017, 02:30 PM
2009 25' FB International
2018 27' Globetrotter
Tavares
Toggle Switch Issue with Jack
My 2009 AS has a Barker VIP 3000 Power Jack. It has two toggle switches. One turns on the light the other raises or lowers the hitch.
The jack raises when I toggle the switch to the "Up" position. However, when I toggle it to the "Down" position it sometimes grunts a bit and then stops. Sometimes if I toggle "Up" and then immediately push it "Down" it will operate as normal. Sometimes it just operates in both directions without issue.
I am assuming this is a toggle switch issue. Your thoughts? BTW a new switch is $45 including shipping (from one source).
Thanks!
07-10-2017, 07:48 PM
2007 22' International CCD
Corona
It could also be a loose/corroded wire. There are six terminals on the back of a typical switch. If one is loose and making an intermittent connection it may act like you describe.
07-10-2017, 07:53 PM
2012 25' FB Flying Cloud
Celina
, Ohio
Remove your bad one and take it
to your local auto parts store, I replaced for less than $25.
07-11-2017, 09:42 AM
Corona
Take good pictures of the wiring, make notes, or label the wires carefully. It would not be fun to mix them up. Just saying....
07-11-2017, 10:20 AM
2015 27' Flying Cloud
Portland
, Oregon
Check connections first, but I had one go bad on the road. What you need is a DPDT toggle switch. That is a double pole, double throw toggle switch. Here is a link to options as low as $5-9: https://www.google.com/?gws_rd=ssl#q=dpdt+toggle+switch
I like Grainger as they are about everywhere. Amazon probably has it too.
The ability to follow instructions is highly underrated.
Always be wary of stupid people in large numbers.
07-11-2017, 10:32 AM
2014 25' Flying Cloud
San Luis Obispo
Personally, I'd contact Barker. It could be one of the switches to prevent the jack from retracting/extending too far is at fault. They are great people to work with and have fast service.
2014 Flying Cloud - 25' RB
2016 Tundra
Air# 42643; WBCCI# 3884
07-11-2017, 11:27 AM
2016 28' International
2015 28' International
2013 28' International
Las Vegas
, Nevada
I second waltb, I have had several of the toggle switches fail-easy to replace, take a photo of wires before you disassemble. Also 2 of the micro limit switches- also easy to replace.
I get both from the local electrical supply store.
07-11-2017, 12:12 PM
2014 25' FB Eddie Bauer
Vero Beach
I had the exact same issue. Called Barker. They sent me a new switch. Problem fixed.
07-11-2017, 12:30 PM
2000 34' Limited
1985 25' Sovereign
LaGrange Highlands
Just had the same prob on my 2000 AS and finely fix it. Took it apart and when I had the motor out it worked. I put the motor back and it did not work some times it worked and some times it did not. By flook I happened to move the power wire going into the motor and it stopped. Found the prob. Wire loose in the motor. Replaced the motor with one I had around, problem solved.
07-11-2017, 01:02 PM
2011 25' FB International
Gunnison
We just had this issue and replaced the switch, now works fine.
07-11-2017, 01:05 PM
Tavares
Yes indeed. Been there and done that before. But a good reminder nonetheless.
07-11-2017, 01:10 PM
Tavares
I ordered the switch from Grainger. Should have it in a day or two. Thanks for the recommendation.
I checked the local auto parts store and they had a switch but with screw attachments, not the quick spade attachment I needed.
07-11-2017, 08:14 PM
2014 25' FB Flying Cloud
Fitchburg
, Wisconsin
But don't forget to check the ground--probably the bolts that attach the jack to the A-frame.
07-11-2017, 10:44 PM
2013 25' Flying Cloud
Redding
I also had almost same issue.....mine was trouble getting it up. Yes, I've heard the joke already. I called Barker and "she" said to replace the micro switch. I did that and had same problem. I then replaced the the DPDT switch as others said and was pleased to solve the problem.
07-12-2017, 05:54 PM
Tavares
Well I replaced the DPDT switch and it works great. No I can get it up... and down again, so all is well!
I blew the fuse when I disconnected the bad switch (the battery cable slipped and touched the positive terminal causing a current flow at the wrong time). So I went about trying to find a replacement fuse. The Barker owners manual calls for a S30A (a slo-blo) fuse. I could not find such a fuse anywhere. I tried all the auto parts stores, even NAPA. Tried Tractor Supply and Home Depot. Nothing! So I stopped at Camping World and ask the service guy what they use and he said they just use a standard 30A fuse. So that's what I got and it works, at least to this point.
Anyone have a place to get S30A fuses or should I just ignore the Barker recommendation? Thoughts?
07-12-2017, 06:09 PM
Sag Harbor
, New York
You probably need the slow blow variety IMO. Search results should have recent threads:
https://www.google.com/search?q=Jack...=airforums.com
We got ours at Napa but the edge of the little box was not labeled correctly so the sales rep had to check the SKU in the computer, and find it that way.
Good luck,
Peter
PS -- From 20-footer thread -- click on arrow in quote to go there:
Originally Posted by OTRA15
I guess you can order online, but your NAPA store should have them IMO. The label on the end of the small box does not indicate Slow-blow, so the counter clerk did not find them right away. A search of the catalog yielded the right SKU.
http://www.napaonline.com/napa/en/p/...335/BK_7821335
On end of small box:
782-1335...QTY
MDL-30........5
07-12-2017, 07:07 PM
Tavares
Good luck,
Peter
Thanks for the information. I'll definitely followup with NAPA. My logic is that there is a reason the slo-blo fuses are specified by Barker.
07-21-2017, 01:41 PM
Tavares
I finally have my 30A slo-blo fuses. They did not have them at the NAPA store (at least that is what they told me).
I ordered a box of 5 from McMaster-Carr Supply Co. They have everything!
Thanks for all the suggestions and input on this, now completed, repair project!
