Old 05-15-2008, 09:44 AM   #1
1996 34' Classic
FordTruck's Avatar
1996 34' Excella
Locust Grove , Virginia
Images: 8
To 'Time Delay' or not 'Time Delay'
I'm having trouble with my power tongue jack on the new 2008 Safari 27FB SE. When the jack reached it's full extension (up or down), the inline 30amp fuse blows. I've gone through many (non-time delay fuses) in only our 2nd time out with the trailer.
Dealer didn't have a clue as to whether a 'time delay' fuse would alleviate the situation. So far, their advice has been "don't do that" and the fuse won't blow. DUH !!!!!!!
FordTruck
2016 GMC 2500HD Denali (Betsy 4)
1996 34' Excella 1000 (Arvin3 as this is our 3rd AS)
2010 TREK 2.3
Fair is where they put ribbons on pigs.
FordTruck is offline   Reply With Quote
Old 05-15-2008, 09:54 AM   #2
soldiermedic's Avatar
Florissant , USA
I have the exact same problem with my trailer. Unfortunately the access to my fuses is damn near impossible to reach. I have burned thought about 6 fuses, and lose power to my brakes and fan at the same time.
If you find an answer....I am all ears.
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 05-15-2008, 11:18 AM   #3
2006 25' Safari
Madisonville , Kentucky
Time Delay
I'm no expert on these things, but the unit is supposed to have a cutoff before it reaches the max/min point. We had a similiar problem after the batteries were dead in storage, and I had to crank manually.
Get your instructions out and look for the 're-syncronizing' page. When the motor is in sync with the jack, the problem should go away.
I looked everywhere for 'slo-blow' 30 amp fuses, and finally found them at a NAPA dealer.
Good luck.
Barru
BSmiley is offline   Reply With Quote
Old 05-15-2008, 11:36 AM   #4
Excella CM's Avatar
1978 31' Excella 500
Venice , California
You could substitute a 30A automatic reset circuit-breaker for the fuse. They're available at autoparts stores.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 05-16-2008, 05:32 PM   #5
1996 34' Classic
FordTruck's Avatar
1996 34' Excella
Images: 8
Took Arvin to the dealer this morning and they installed an inline automatic re-set circuit breaker. That should end the issue.
I'll take pictures of the install and upload them as soon as I get the camera out.
FordTruck
2010 TREK 2.3
Old 05-16-2008, 07:12 PM   #6
Florissant , USA
Really interested in seeing this. Any idea where I can get the part for my own install?
Steve
Old 05-16-2008, 07:21 PM   #7
lewster's Avatar
Naples, FL , Hood River, OR
Steve
I don't know if they sell to individuals, but try Waytek Wire : Electrical Wiring Supplies & Industrial Products and look at the circuit breaker section.
If not, let me know and I'll get one for you with my next order!
Old 05-16-2008, 08:18 PM   #8
Excella CM's Avatar
Venice , California
Auto-reset breakers are standard auto part store stuff. They come with screw terminals or with ends to fit in a "Buss" fuse holder. Here some made by cole Hersee
Old 05-17-2008, 09:03 AM   #9
1996 34' Classic
FordTruck's Avatar
1996 34' Excella
Images: 8
The circuit breaker installed in our unit looked exactly like the center one (silver) in the picture posted by CM.
I think the comments by others that this is readily available at autoparts stores is correct. I took advantage of having Arvin at the dealer for some minor warranty work to have the circuit breaker installed. As it wasn't "original", I paid out of pocket for the install. Small $$$'s in light of the aggrivation factor for constantly blown fuses.
Hopefully, able to post pics in the next day or so.
FordTruck
2010 TREK 2.3
Old 05-17-2008, 11:08 AM   #10
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Re-sync comes to mind. The limit switches should cut the motor off before the jack bottoms out.
Michelle TAC MT-0
Sarah, Snowball
Old 05-20-2008, 02:33 PM   #11
1996 34' Classic
FordTruck's Avatar
1996 34' Excella
Images: 8
Here is a pic of the circuit breaker connection. It is in the battery box. I hope this helps.
FordTruck
2010 TREK 2.3
Old 05-20-2008, 02:58 PM   #12
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Sounds to me like it's time for the dealer to replace the jack! Never saw a fuse on the battery like that before for a jack. I agree with previous post that the motor should cut out before reaching the jacks extension limit both up and down. Get after them and let us know how you make out. Changing the fuse type will not stop the cause only delay further damage.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
A time to buy, a time to sell jeffyockey@m Member Introductions 2 03-12-2008 10:39 PM
Brake delay on new 31' Classic trvler Brakes & Brake Controllers 19 03-05-2007 01:23 PM
first-time poster.....long-time reader ("lurker") happyfella Member Introductions 3 08-21-2006 08:55 PM
Part Time vs Full Time (Days/Year) InsideOut Community Polls 30 10-23-2005 09:43 AM
Sub-woofer needs delay circuit M&M CAPECOD Audio, Video & TV 9 05-22-2005 01:52 PM
