10-29-2015, 03:00 PM
2015 27' FB International
mesquite
Tire Changing Aids
saw somewhere that there is a yellow plastic ramp that you drive a wheel on and it lifts the flat tire [dual axel] off the ground . don't really know the name but think its called [ easylift]
has anyone used one ? in my case 16 in. rims and wheels/and how good is it and do you recommend using one?
2015 27ft. internation sig. with 16in tires.
10-29-2015, 04:35 PM
1978 Argosy Minuet 6.0 Metre
Wauwatosa
, Wisconsin
Google "Camco Trailer Aid"
Walmart has them also Camping World and I would think most RV/Trailer sales.
Judging a person does not define who they are, it defines who YOU are.
10-29-2015, 06:05 PM
2007 30' Classic S/O
Somewhere
, South Carolina
I didn't see the full TV details but if it's 3/4 or a 1 ton you most likely have a seriously good Jack that came with your truck. Take a look.
10-30-2015, 03:02 AM
mesquite
airstreamtrailer
I should have been more explicit.
I meant the trailer aid used for changing a tire on the airstream. Has anybody used one and how did it work? Where did you purchase it and how much?
10-30-2015, 04:49 AM
Wauwatosa
, Wisconsin
$30 Walmart (yellow) $35 (black)
Yes they work great
10-30-2015, 01:40 PM
Somewhere
, South Carolina
Nope, understood clearly. I have on from previous owner. I did use it one time. Just offering an alternative tool that you already have at hand.
I own a pair of these screw jacks from 1 ton pickups. Last weekend I had both sides up, 4 tires removed, bled brakes and rotated the tires. And my AS is over 9,000 lbs dry and empty.
10-30-2015, 03:15 PM
I'm In
, Kentucky
Trailer Aid Plus
I got the Trailer Aid Plus on Amazon. It's still in the box, haven't used it, hope I never have to in an emergency. But it's there, just in case.
http://www.amazon.com/gp/product/B00...ilpage_o09_s00
There's some pictures and a video at the above link.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
10-30-2015, 03:42 PM
2020 28' Flying Cloud
Upper St Clair
, Pennsylvania
As stated trailer aide. Ours is yellow. Never had to use it in a tire emergency, but the tire dealer used it to take off the 15" we had on our old 30' and put on the new 16". There are only a few places that one can safely jack up an AS using a bottle jack etc. so the dealer said he would use the ramp. Worked great.
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
10-30-2015, 05:29 PM
2012 25' Flying Cloud
Battle Lake
We have the Trailer Aide (not the Plus) and I used it to take off all the original tires and put on new Sendel wheels and 16" Michelins. Very easy and safe to use.
Doug and Cheryl
10-30-2015, 06:04 PM
2015 28' Flying Cloud
2014 25' Flying Cloud
Waxahachie
I have used the Trailer Aide on my horse trailer and it works great. I have heard of folks using their lynx leveling blocks on one axle as well basically doing the same as the Trailer Aide.
11-02-2015, 02:16 PM
Ready-to-Travel
2012 30' International
Walkerton
, Virginia
I have the traileraide too. Not only do I use it when I change tires but I insist that my tire guy use it whenever he needs to raise a tire (such as when checking the brakes). Much safer for the rig not to depend on proper placement of a jack.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
11-02-2015, 02:59 PM
Rivet Puller
2003 28' Safari S/O
Atlanta Burbs
, Georgia
The benefit of the plastic ramp is light weight. I used a piece of 2x8 left in my shop to make a 3 layer ramp ($0 out-of-pocket). It works just as well but weighs considerably more. I leave it in the bed of my truck. You can build the same ramp with the six of the 'lego' blocks if you have them. A jack works too but I would rather use the ramp approach.
11-02-2015, 04:20 PM
2005 30' Classic
Burlington
, Ontario
There may be some advantage to the type you describe, but I have always used the
Lynx Levellers for the same purpose and they work fine.
What I like about them is that they can also be used as pads for the stabilizers / tongue jack, or under the wheels of one side of the trailer in the event of an uneven site.
In fact I guess that is their primary purpose - but nice to have something that can serve for several tasks.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
11-02-2015, 04:35 PM
2007 28' International CCD
Springfield
, Missouri
I use Lynx Levelers and they work great.
11-02-2015, 06:17 PM
2004 31' Classic
lubbock
I have one ... It s grrrrreeeeeaaat!!
I ve used it 3 times and it is a lot easier than using jacks, jack stands & it s much safer (my opinion)
Highly recommended
