Steve,
I'd be curious to see two side-on photos of your setup. The first with the hitch head simply installed in the receiver ( no trailer ), and the second with the trailer loaded and weight bars tensioned.
Originally Posted by MrUKToad
For the OP - Friction sway control bars:
The bit with the white "Draw-tite" sticker on it.
Loosen off the tension using the handle, the direction is indicated on the sticker, remove the clips from each end and simply pull from the two mounting balls. To refit, place the bar ends on the two balls, fit the clips and then tension using the handle. If the sway bar is hard to remove I can only think that you're not releasing the tension first.
