Old 04-01-2009, 10:46 PM   #1
chrisd37's Avatar
1976 31' Sovereign
Marietta , 30064
Super Jack limiter fail
I raised my Super Jack too far and it ate up the #2/#3 "fiberboard" gear. $50 later another gear assembly will be here on Friday. This jack supposedly has a limiter switch but I guess its operation is beyond me. Shouldn't it have stopped before it did a #2 on my #2/#3? Should I just draw a warning line on the jack post that tells me "if you see this line, STOP" and forget about the supposed limiter switch? (and thank you to the people who came before me in this for providing info here on getting another #2/#3)
chrisd37 is offline   Reply With Quote
Old 04-01-2009, 11:41 PM   #2
2010 27' FB Classic
N/A , Texas
When my Super Jack finally bit the dust I opted to buy whatever Camping World had on the shelf. Big mistake! It lasted about 1 season camping. I bought another Super Jack since as the original one lasted me over 20 years.
The idea about the line(mark)on the shaft is a good idea. Getting the part and fixing it was actually a less costly way to go for you. I lost a couple of hundred $ on that Camping World piece of crap. I'll never do that again.
Old 04-02-2009, 07:01 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
There is a set up to ensure the limit switches engage before the jack screw reaches it's limit.
I don't have that procedure in front of me and I am about to leave but if you call the manufacture they will have it. Check it out before you replace the gears.
2004 Excursion 4x4
Old 04-02-2009, 08:29 AM   #4
1996 34' Classic
FordTruck's Avatar
1996 34' Excella
Locust Grove , Virginia
Images: 8
I've had trouble with my jack eating up the gears since we bought it. The last time I took it to the dealer, it ate up the gear while they were operating it. They put in a new gear and it ate up that one too. They replaced the 2nd one and said I should try using it and if I have any more trouble with it, they would replace the whole thing.
They said they believe the manufacturer was using the wrong material for that gear.
FordTruck
2016 GMC 2500HD Denali (Betsy 4)
1996 34' Excella 1000 (Arvin3 as this is our 3rd AS)
2010 TREK 2.3
Fair is where they put ribbons on pigs.
FordTruck is offline   Reply With Quote
Old 04-02-2009, 10:19 AM   #5
Dan@LED4RV's Avatar
Denton , North Carolina
jack parts
Chris,
That is a bit of a bummer. I would like to shead a little light on the problem and what happened for others who are reading this.
The limit switch has a plastic wheel that has two little barbs or tits that run into the limit switches.
If the timing is set up right the jack stops once it encounters the limit switch. At that point, if your unit has not gone high enough then you have to go the other way to be able to put wood under your jack and the get it high enough to be able to disconnect the unit(get the trailer on/off the ball). If one of those tits breakes off then the limit switch will not cut off the and the fiber gear will get in a real bad strain and teeth will come off. Then both parts will have to be replaced.
I tried a few times to glue my own tits on the wheel and had NO luck in doing so.
The only other thing I could suggest is get a feel for the sound of your jack and if it sounds like it is straining to hard stop and put more wood under the jack.
Dan
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 04-02-2009, 10:31 AM   #6
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
I can't speak to the operation of motorized jacks on the older model Airstreams, but on at least the jack used on our '06 there is a "calibration" process that you have to go through, espcially if you remove the motor head (don't ask how I know this). I don't remember them off the top of my head, but it was in the instructions in the paperwork that came with our '06.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 04-02-2009, 10:32 AM   #7
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
Did this on the way home when we first bought the trailer. The setup procedure is on the sticker attached to the jack on ours. Basically, it involves setting the jack with the manual crank to a specified location. Then the motor is run to one of the limit switches (I forget which one) while it's off the jack. The basic idea is that the motor should stop because of the limit switch before the jack reaches the mechanical stop. Obviously, if the jack reaches the mechanical stop before the motor stops, the gear has gotta give.
For $50 the local Airstream dealer sold us a new gear. The installation of the gear and the setup procedure were pretty simple. I have a copy of those instructions somewhere in the trailer. I'll look around and see if I can find them. Will post them when I can.
The PO wasn't much of a mechanic, but he was great about keeping the paperwork.
Old 04-02-2009, 01:33 PM   #8
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
I had an issue with ours that it kept blowing fuses. One of our more knowledgeable forum members told me about one of the issues that happens while I was at a forums rally. The hot wire runs under the tank cover and over time the tank cover can crush the wire or rub against it breaking the insulation on the wire. Upon inspection I discovered that the insulation was indeed broken right at the area where the wire runs under the cover. I cut the broken insulation section of the wire out and spliced the wire together with an appropriate sized wire nut and then taped the heck out of the junction with electrical tape to insure that no water could inter the splice. I haven't blown a fuse since. I had really become quite tired of taking the head off and hand cranking the tongue every time and reinstalling the head before hitting the road for each leg of a trip.
On a tangent note. I was at the Florida State Rally and was going to have Camping World replace the Super Jack while I was there. The model they sell has a light on each side and the bolt holes wouldn't line up so the tank cover and the Pole-ez flag pole holder wouldn't be in the way of the lights so they didn't replace it. The issue that remains is that the gear has some teeth that are evidently missing as it clicks or skips as it lifts under load. I didn't realize I could replace just the gears. I'll have to do that in the near future.
Family of Disney Fanatics
WBCCI# 4821
Old 04-02-2009, 04:14 PM   #9
Senshi's Avatar
1980 25' International
Napanee , Ontario
I stripped the gear in my trailer as soon as I got it home. I was lucky to find an entire motor head that was in good condition except that the limit switch was not working on it as well (I ran the motor for a long time both directions when it was off the shaft and it would never shut off). Where is this limit switch located? When I had the top off the gear box there was nothing of like that to be seen.
Senshi is offline   Reply With Quote
Old 04-03-2009, 06:20 AM   #10
chrisd37's Avatar
1976 31' Sovereign
Marietta , 30064
Hey, cool, I had my trailer two whole weeks before stripping the gear. It sounds like I am doing well! Heh heh.
Dan4ods (I think I am buying a couple panels from you right now) I do have the white plastic box with wires and the white plastic gear. I figured that was the limiter switch but could not see what would push the bendy thing back and forth to change the circuit to "stop". I will look for some tits on the plastic wheel. They could be there and I just didnt notice them.
I should be able to calibrate the limit switch without too much trouble assuming it has the bits intact to push the cut off thing back & forth at its limits. I understand now what is supposed to happen. That's good news.
I will also go with painting or stickering a red warning section on the jack that, when seen, means "you are about to spend $50, pal." A yellow bit might be in order just beneath the red. These will only be visible when the jack is really high, so they wont detract from the appearance under normal circumstances.
Putting wood under the jack is a great idea. I have a block of wood that came with the trailer. I thought that was just to keep the jack from messing itself up on the bottom against the driveway and possibly to level the surface. More/taller wood underneath the jack to get the jack operating on a higher plane relative to the tow ball is clearly the voice of experience. Thanks!
Old 04-05-2009, 10:38 AM   #11
1966 22' Safari
Weatherford , Texas
I finally got to the instructions for the Super Jack. My scanner is down, so I'll just copy the section about synchronizing the jack here.
IMPORTANT - REPLACING THE POWER HEAD
It is ESSENTIAL that the following procedure is used BEFORE power head is replaced on the post.
1. With 12 volts connected, ground the power head to trailer "A" frame. Operate main switch in the "post retracting direction" until the motor stops automatically.
2. Using emergency handle, crank the post clockwise by hand until fully retracted then turn crank ONE TURN counterclockwise.
3. Replace head on post and make sure that drive pin is engaged with post coupler. Tighten allen set screws.
I would also suggest running the motor both directions while the head is off the jack to confirm that the limit switches do indeed work.
One new gear and the synchronizing procedure above seems to have fixed ours.
Best of luck.
Old 04-13-2009, 04:52 PM   #12
chrisd37's Avatar
1976 31' Sovereign
Marietta , 30064
Thanks! But it turned out my limiter switch does not work. One white plastic gear does not turn the other one.
Super Jack repair dedko Jacks, Stabilizers, Lifting and Leveling 8 11-05-2012 06:49 PM
How do you manually crank a Super Jack flyfisher Jacks, Stabilizers, Lifting and Leveling 7 06-20-2011 09:53 AM
Goodyear Marathons from 06 and 07 fail... norsea Tires 10 03-03-2009 10:13 AM
Barker H & H Super Jack Problem-HELP!!!! AirHog Jacks, Stabilizers, Lifting and Leveling 3 04-29-2004 08:43 PM
Super jack parts ctdair Jacks, Stabilizers, Lifting and Leveling 1 04-27-2004 07:49 AM
