Old 04-05-2016, 05:13 PM   #1
2021 25' Globetrotter
Oracle , Arizona
Super Jack Fuse dimensions
Still working through the endless list of recommended accessories prior to picking up our Classic.... As suggested in the forum, I have been looking for a couple extra 30A 250V slow blow glass fuses, and I believe I have found an on-line source at fuseco.com. They have a question I have been unable to answer: does the fuse measure 1/4" x 1-1/4", or is it 5 x 20mm?? Thanks in advance for anyone's help on this!
JVfromGrnBay is offline   Reply With Quote
Old 04-05-2016, 06:04 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Do it the easy way, go to NAPA to get your fuses. Normal stocking item for them. They will know exactly what you need. Just tell them 30 Amp slow blow glass fuze, stress the slow blow.
MICHAEL
Old 04-05-2016, 06:04 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Howdy... presuming you are 'buying new'... have the 'dealer' throw in a handful of the fuses.. On the fuse he/she gives you, there will be a special letter sequence.. that will tell you the 'type/size' of the fuse.... I have only 'blown' one fuse on the AS... that is because I 'shorted' out the power wire.
Peace and Blessings..
Channing
WBCCI# 30676
Super cab or super crew ? Papa smurf Tow Vehicles 30 12-24-2014 09:19 PM
Super Jack repair dedko Jacks, Stabilizers, Lifting and Leveling 8 11-05-2012 05:49 PM
2005 Classic Super Jack Fuse Location ken.bauman General Repair Forum 0 05-05-2012 01:53 PM
Barker H & H Super Jack Problem-HELP!!!! AirHog Jacks, Stabilizers, Lifting and Leveling 3 04-29-2004 07:43 PM
Super jack parts ctdair Jacks, Stabilizers, Lifting and Leveling 1 04-27-2004 06:49 AM
