Old 04-20-2015, 07:27 PM   #1
2007 28' Safari SE
Deland , Florida
storing and raising Safari off tires
I had an issue with a bad tire and was told by Airstream to jack up my 27' Safari to get the weight off the tires-where is the proper place to jack it up when it is not being used and stored under my carport?
Jeffg24 is offline   Reply With Quote
Old 04-20-2015, 07:40 PM   #2
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
This is what I was told by someone on Airforums. I made a note I case I ever needed the info. I don't believe this is necessary unless you are looking are a fairly long storage time.
"Placing airstream on jackstands: 2 on backside of A frame, 2 at the frame at the bumper, 2 at the axle mounting plates behind rear axle ( jack placed on mounting plate between axles)"
Landrum is offline   Reply With Quote
Old 04-20-2015, 08:13 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Do NOT jack on the axle!
Lift with jack on the vertical plate where the axle is mounted to.
Make SURE the trailer is connected to the TV or other way secured from moving!
Do not try to jack on the rear end. That can be a death blow.
Peace and Blessings..
Channing
WBCCI# 30676
Old 01-03-2017, 06:56 PM   #4
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
I jacked up between the wheel on frame part, put a 2 ton jack on same frame part and slowly lowered that side. It took appx 90% of weight off tires.
Will post pictures to show jacks soon.
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Raising the 'Blimp' for Wyo Dirt Roads fotozone Modifications 25 11-02-2009 12:28 PM
raising a 345mh 345bill Classic Motorhomes 2 12-31-2007 10:32 AM
Raising the Flying Cloud dmaiden Axles 22 12-26-2006 04:15 PM
raising the trailer atvmcg Repairing/Replacing Floor &/or Frame 9 11-18-2005 09:10 AM
Raising Trailer Height John Sims Axles 2 06-24-2003 10:52 AM
