Old 02-13-2016, 12:47 PM   #1
Registered User
Grand Bay , Alabama
Stablizer jacks replacement with scissor jacks
Has anyone replaced there original stablizer jacks with scissor jacks? Is there a problem in doing this.
spoonplug is offline   Reply With Quote
Old 02-13-2016, 12:50 PM   #2
1994 30' Excella
Mississauga , Ontario
I think you might lose some ground clearance. I also think they look ugly. Maybe that's just me!
Al
Al and Jean
TAC ON-3
Old 02-13-2016, 01:02 PM   #3
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Ditto.....
Old 02-13-2016, 01:36 PM   #4
Why ??
They don't stabilize and more than what you already have, they also add weight to the rig, they look ugly on an Airstream, they lower the ground clearance, AND, they put a drain on your pocket book.
Old 02-15-2016, 12:53 PM   #5
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
OlyPen , Washington
Images: 90
Originally Posted by Inland RV Center, In View Post
Why ??
But... if you do replace them, can I have the old ones please?
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 02-15-2016, 01:38 PM   #6
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Even if you do buy free-standing scissor jacks, it's probably best if you don't use them to "jack" the trailer - just stabilize. Scissor jacks are quite a bit stronger than conventional Airstream stabilizers.
Experts here can confirm / deny, but as far as we understand it, those aren't jack points and actually lifting the trailer at these locations could create unfortunate frame-twisting results.
Rocinante is our 2014 International Signature 27FB
Old 03-25-2016, 07:35 AM   #7
Toronto , Ontario
I would like to hear an expert response to the above. I have seen scissor jacks advertised in links from this site for use to level an AS. This would imply that there are suitable points to raise one side from without risking twisting the frame. I know the stabilizers are not intended to level. If this is safe a safe practice it would be great if someone could confirm this and advise where best to place the jacks. Thanks.
nskinner is offline   Reply With Quote
Old 03-25-2016, 07:50 AM   #8
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Honestly, the best location for leveling jacks on an Airstream is in the nearest dumpster. NEVER level an Airstream travel trailer using those jacks. EVER. For any reason. The list of Bad Things that will (not might) happen is too long to list here. First problem is tweaking the frame, which is not designed to carry the weight of the entire trailer in a single concentrated point, second, little things, like the main door not opening or closing when jacked up, and many times after the jacks being lowered. The list goes on.
Old 03-25-2016, 08:51 AM   #9
Lifting jacks are almost always a hydraulic type of jack.
Stabilizing jacks are exactly that, as they will fail if used to lift the trailer.
When lifting the trailer with jacks, they should be place on the verticle axle mounting plate. For single axle trailers, place the jack rearward of the tires. For tandem axle trailers, place the jack between the tires. For the triaxle trailers, place the jack between the middle and rear tires.
Stabilizing jacks that are not mounted, should be placed on the A-frame and the frame at the bumper. For longer tailers, another stabilizing jack can be placed between the 2 axles on the axle mounting plate.
Stabilizing jacks should NEVER EVER be used to lift the trailer.
Old 07-17-2016, 10:33 AM   #10
1975 31' Romany
Kansas City , Missouri
What is the reason Dexter says not to use the scissor jacks at the axle. I see no difference between driving a tire up on a leveling block and jacking it at the axle under the frame mount. It would seem to put the same pressure on same contact point
kosullivan is offline   Reply With Quote
Old 07-18-2016, 06:30 AM   #11
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
You would most likely crush the axle using a jack under it, I use a 12 ton hydraulic bottle jack on the frame mount with a piece of 1/2 " steel between the frame and jack so the pressure is on the verticle surface and not on the flange as it will bend.If I had a scissor jack , I would toss it, a 8-10 ton hydraulic jack can be had for $30....
Old 04-29-2017, 11:03 AM   #12
Goliad , Texas
I see no problem but I am no spert
I am in the process of installing FOUR 30" scissors in place of the TWO broken ones on the bumper.
I weighed the two originals with brackets. I am adding TWO extra pounds so Andy's comment about adding weight is true but not that much to be worried about.
For me to replace with ORIGINAL jacks it would have cost me $135 for TWO vs $65 for FOUR scissor jacks. Installation is a wee bit more for four but I now am going to be a lot more stable when I set her up.
Of course I am not installing them back where the original bumper stabilizers are and am installing them by welding directly on the frame. I failed to mention that I am about 90% done with a 65 Overlander restore and am in process of getting ready to install belly pan.
The Frommes
Goliad, Texas
The Birth Place of S. Texas Ranching
WBCCI #6256
eartick is offline   Reply With Quote
Old 11-24-2018, 02:25 AM   #13
2008 19' Safari SE
Cary , North Carolina
My conundrum is a bit different.
My son was rushing around lowering the stabilization jacks before I had leveled the front to back pitch with the tongue jack. To finish leveling the Airstream, I raised the foot(lowered the front) and all the front weight was briefly supported by the stabilizer bar. Once I realized our mistake I immediately took the pressure off the stabilizer jack.
1-Do you think i damaged anything?
2-Where should I check for damage.
3-what are the possible damage areas.
The attachment plate is mounted to the frame that bears weight seems to be attached to the frame.
All replies are appreciated. Thank you.
2008AS is offline   Reply With Quote
Old 11-24-2018, 05:50 AM   #14
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Is your door at the front? If so, check to see that it is opening and closing the same as before. If it is then likely no problem.
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is offline   Reply With Quote
Replacing original stabilizers with scissor jacks FishHouse Jacks, Stabilizers, Lifting and Leveling 1 10-25-2010 04:14 PM
Scissor Jacks in Front? J Goertzen 2002 - 2005 International 1 07-02-2008 01:46 PM
Scissor jacks/unhitching J Goertzen Jacks, Stabilizers, Lifting and Leveling 3 06-24-2008 04:55 PM
Scissor Jacks on 23' Safari SE LS OrangeKid 2007 Safari SE 10 11-14-2006 04:37 PM
