Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Jacks, Stabilizers, Lifting and Leveling
Old 01-20-2006, 05:26 PM   #1
wayne.yl's Avatar
Profile:  1977 31' Sovereign
1992 34' Excella
Salem , Oregon
Stabilizing Jacks for 77 sovereign
I am needing any info on replacement of stablizing jacks for our 31ft trailer. Only one is broken and wondered if you can buy just one to replace. They are a scissor type manuel jack that operates by cranking w/ a tire tool. After dissassembling the broken jack, I found that just one part of the aluminum assembly is broken. Is it possible to replace just that part?
thanks,
Wayne
wayne.yl is offline   Reply With Quote
Old 01-20-2006, 05:29 PM   #2
juel's Avatar
Profile:  1978 Argosy 24
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
Yes, it is possible to just buy one jack. You can get them at almost any RV store and have them put on. You can try Vintage Trailer or Camping World on the web if you think you can put one on yourself. This is usually an easy fix. I had two replaced on my Argosy when I took it in for the new A/C. No problem.
juel is offline   Reply With Quote
Old 01-20-2006, 05:33 PM   #3
wayne.yl's Avatar
1992 34' Excella
Salem , Oregon
Juel
Thanks, I will look them up.
Old 01-20-2006, 05:43 PM   #4
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 156
Airstream Registry
Stablizing Jacks for 77 sovereign
Greetings Wayne!
The stabilizer jacks were typically BAL and are available from most RV parts sources as Juel indicated. You may find that you need the special BAL stabilizer jack for Airstream that has an extended drive that places the point where the handle attaches closer to the edge of the banana wrap. The first set of stabilizers on my Overlander didn't have these extensions (had Camping World install them before realizing that there was a special extended model available for Airstreams) -- I later had the BAL stabilizers with the extension designed for Airstream installed on my Overlander as well as my Minuet.
Good luck with your search!
Kevin
Kevin D. Allen
AIR #827
Old 01-20-2006, 07:17 PM   #5
fastrob's Avatar
Profile:  1976 25' Tradewind
Mount Vernon , Maine
Go BAL
I just purchased 4 (2 sets) of 5000lb capacity for my 25' Tradewind for about $140 at a local RV supply. They had the 7500lb size also but were unnecessary for my needs. I had the broken aluminum units which I threw away, did not like the way they folded up from abuse. I believe the weight of steel is worth the advantage in toughness.
fastrob is offline   Reply With Quote
Old 01-21-2006, 07:05 PM   #6
wayne.yl's Avatar
1992 34' Excella
Salem , Oregon
Thanks fellas,
i agree w/ you about the advantages of steel but do these versions compromise my commitment to restore the trailer to original. do I need the aluminum ones in keeping w/ what I am replacing. What does Bal mean?
Wayne
Old 01-21-2006, 08:13 PM   #7
McHenry , Illinois
BAL is a manufacturer's name. They also sell Bal sand pads. Which are round plates which attach to the bottom of the stabilizers and make it so they do not sink into soft ground. I put them on my unit because I park on grass alot. The screws tend to get full of junk on the bottom of the trailer and also rust. Clean and lubricate the screws in the begining of the season and again before you put it away for the winter.
Old 01-21-2006, 08:14 PM   #8
My Grandparents Airstream
Andrew Selking's Avatar
Profile:  2007 25' Safari FB SE
Fort Worth , Texas
Send a message via AIM to Andrew Selking
Bal is the brand name of your jacks.
It is your choice to keep it original or change to the steel jacks.
Lots of people do change them out because the aluminum ones get bent or torn up.
Good luck which ever way you go.
Andrew Selking
WBCCI #6062 VAC
"Airstream the Best trailer ever built."
Andrew Selking is offline   Reply With Quote
'78 Sovereign Awning Joan D'Andrea Awnings 6 01-03-2006 07:34 AM
Tiny fan to bedroom of Sovereign helps cool and warm the space Joan D'Andrea Cabinets, Counter Tops & Furnishings 2 11-02-2002 11:10 AM
85 Sovereign 25' j54mark 1985 Sovereign 7 10-30-2002 09:23 PM
1978 AS Sovereign and doing my own repairs JLD Our Community 2 09-05-2002 11:28 AM
Help with Ancient Sovereign patti 1956 Sovereign 2 06-06-2002 02:23 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
